Hatch pattern
stickitwelding
Hatch pattern
Post by stickitwelding »
Morning everyone, is there a way to do hatch patterns in design edge i dont know about? ive been playing with Inkscape to it but cant figure out how to make a hatch join inside text for when i import into design edge.
Re: Hatch pattern
stickitwelding wrote: Fri May 31, 2024 11:11 am Morning everyone, is there a way to do hatch patterns in design edge i dont know about? ive been playing with Inkscape to it but cant figure out how to make a hatch join inside text for when i import into design edge.
hatched text.dxf
Re: Hatch pattern
hatch fill.dxf
stickitwelding
Re: Hatch pattern
You give direction so well, thank you!
Joe Jones
Re: Hatch pattern
Post by Joe Jones »
Are you going to use the engraver to put the hatch pattern onto the text? This can be done in DesignEdge.
Re: Hatch pattern
stickitwelding wrote: Sat Jun 01, 2024 8:45 am You give direction so well, thank you!
You are quite welcome! Let me know if you have any questions about using Inkscape to automatically create your hatch patterns.
Joe Jones
Re: Hatch pattern
Post by Joe Jones »
What do you mean by "how to make a hatch pattern join inside" in DesignEdge? I am unclear on what you want to do.
stickitwelding
Re: Hatch pattern
ya Joe, i was playing with the easy scriber i just got, but i got it all figured out now.
Joe Jones
Re: Hatch pattern
Post by Joe Jones »
That is great, but I thought your question was, “how do you hash pattern into text, using DesignEdge software?“
Re: Hatch pattern
Joe Jones wrote: Mon Jun 03, 2024 12:47 pm That is great, but I thought your question was, “how do you hash pattern into text, using DesignEdge software?“
Likely easier to do the hatch pattern in Inkscape and open in DesignEdge unless you have a trick up your sleeve Joe......
Re: Hatch pattern
plasmanewbie wrote: Tue Jun 04, 2024 1:08 pm
Yes - that is exactly what the OP was looking to do. He could not find a hatch pattern tool in Design Edge, so had been messing around with Inkscape - which does have several hatch pattern tools. I suspect his problem was that he may not have been converting his text to paths before saving to import to Design Edge. I believe that I was able to put him on the right path and he can now achieve his goal.
stickitwelding
Re: Hatch pattern
so i did a few practice letters the other week that worked out well but now im having an issue with this file when trying to make a cut path. im sure its something simple. Attached is the file made with Inkscape.
Gulls issue.pcm
Joe Jones
Re: Hatch pattern
Post by Joe Jones »
You must do a DOUBLE outline of the letter in order to set such a design into the interior. I did a video on this ... Looking for it .... :roll: Ah! Found it! :mrgreen:
Re: Hatch pattern
stickitwelding wrote: Thu Jun 13, 2024 9:44 am so i did a few practice letters the other week that worked out well but now im having an issue with this file when trying to make a cut path. im sure its something simple. Attached is the file made with Inkscape.
Let's keep it simple.
Re: Hatch pattern
You can also do the offsetting in Inkscape before you save as dxf for import to Design Edge. Then when you open with Design Edge, simply create your cut paths for engraving and cutting.
