Need Enroute help
Mr.Dirt
Need Enroute help
Post by Mr.Dirt »
I am trying to cut smaller pieces that fall out before the cuts are all done.
What is the best way to solve this? I use Enroute.
Mr.Dirt
Re: Need Enroute help
Post by Mr.Dirt »
Any help out there?
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
Not sure if this is what you are asking, but if the piece falls out before you get all the rest of the cuts done, this is usually a layer issue. You need to set your pieces up so that it cuts the inside pieces first, then cuts the outside pieces. Without knowing what software you are using, it is hard to say how to do this.
Torchmate CAD
Mr.Dirt
Post by Mr.Dirt »
Enroute 4 is the software that I use.
