Duramax Machine torch with 220777 electrodes...
Oldsarge
Post by Oldsarge »
I bought a set of these electrodes, and I understand that they should be a direct exchange for the "normal" electrodes. I put a brand new set of these electrodes and a new fine cut nozzle, and started a file. Touched off fine, then after the first cut, the torch won't fire, just a tiny spark and nothing... Am I missing something with the consumable set?
Hypertherm 1250 with Duramax upgrade torch...
Oldsarge
6x12 Home Built Table
Hypertherm PowerMax 85
Re: Duramax Machine torch with 220777 electrodes...
Post by jimcolt »
Sarge,
I guess I would try swapping out the consumables one at a time to determine where the problem is. There are thousands of people using the new electrode......si I suspect they generally last longer than 1 start!
Jim
redduke
Post by redduke »
Tried one also ! 45 amps fine cut nozzle. Had a problem with it and called Hypertherm tech line. Was told to use them for 65 amps. Powermax 65 plasma cutter.
