Protective coating help
I Lean
Re: Protective coating help
Post by I Lean »
I've just used Rustoleum Crystal Clear from spray cans and it seems to work just fine so far.
boodog710
Post by boodog710 »
I use the same. Crystal Clear Enamel. Works great.
hinesigns
Post by hinesigns »
A product I have used over 1SHOT sign enamel & many other coatings is FROGJUICE. It is manufactured by Superfrog enterprises in Moorehead Min. It is a quick dry, crystal clear finish & comes in a rattle can or quart can. It now also comes in many colors.www.far-from-normal.com. Kirk Anton is the contact & tell him Bob sent you.
steelfx
Post by steelfx »
Michman wrote:I have been doing a lot more copper patina finishing lately, and have been trying a lot of different protective coatings...but not crazy about them. Can someone give me some ideas of what I can use? On a few I have done...after a few days I can see this white haze or scale start to appear around the edges ..under the coating.
I haven't tried 'frogjuice' (sounds interesting), but after trying 25+ Clears on my steel artwork, this is by FAR my
favorite.
Bill
p.s. I get a 'full-cure' in less than 10 minutes using an IR lamp. :)
Groth
Post by Groth »
How is the Deltron applied?
steelfx
Post by steelfx »
Groth wrote:How is the Deltron applied?
With any decent quality spray gun. I use IWATA, but other brands should work well, too.
You will need a 1.3mm or 1.4mm fluid nozzle, air nozzle & needle. The one I sell on my
website comes equipped with all & ready to use.
Groth
Post by Groth »
Ok, Thanks..
richarddgr
Post by richarddgr »
I use a clear powder coating.
