Adding a bending gauge
All topics related to bending, forming, notching, drilling, saw cutting, etc.
Willdamnit
Post by Willdamnit »
I wanting to add a bending gauge. I've 3d printed a part I've started designing I've looked for something similar but all my searches came up with external gauges which what I'm not looking for. I use a digital gauge but I'd like to add one either side for quick bends.
Thanks any help or insight would be appreciated.
05Duramax
Re: Adding a bending gauge
Post by 05Duramax »
Pretty cool. Would be slick if you could 3d print the numbers for the angles into that part. Could then use a white paint marker to highlight the numbers.
Willdamnit
05Duramax wrote: Sun Mar 09, 2025 7:17 pm Pretty cool. Would be slick if you could 3d print the numbers for the angles into that part. Could then use a white paint marker to highlight the numbers.
I'm currently working on the model in fusion. I'm 3d printing it with an indicator and number when I have a working concept I'll make the frame from metal then make the dial 3d printed.
This is one that might work for your application with a few modifications.
Here is the step file you can download from my Google Drive. Fusion 360 will open this file directly for editing, printing, etc.
https://drive.google.com/file/d/1B6gQ9r ... sp=sharing
Joe Jones
Post by Joe Jones »
Create a cable device that will let you see the degrees of bend by viewing a wall mounted indicator. Scale the components as desired.
BRAKE BEND GAUGE WALL MOUNT PCM.pcm
BRAKE BEND GAUGE WALL MOUNT DXF.dxf
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
Joe Jones
Post by Joe Jones »
Or use one of these. Mount it where you can see the display.
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Joe Jones
Post by Joe Jones »
I use these to keep it SIMPLE.
Mount one to each side of the brake.
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
05Duramax
Post by 05Duramax »
So many great ideas! Interested to see what you end up doing, please post back.
If you want to have the numbers printed on the gauge in a different color you can put a pause in the G-code and switch filaments. I did that some time back on a dial I printed. Using the preview in the slicer program to move to the transition of the start of the number print and put a pause there and change the filament color. Resume the printing to complete.
05Duramax
Post by 05Duramax »
acourtjester wrote: Wed Mar 12, 2025 11:54 am If you want to have the numbers printed on the gauge in a different color you can put a pause in the G-code and switch filaments. I did that some time back on a dial I printed. Using the preview in the slicer program to move to the transition of the start of the number print and put a pause there and change the filament color. Resume the printing to complete.
That would be pretty cool, I didn’t realize that was possible!
Joe Jones
Post by Joe Jones »
I think the Starrett magnetic mount gauges are the K.I.S.S. solution.
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Willdamnit
That is the plan the Bambu p1s paire with an Ams.
Willdamnit wrote: Wed Mar 12, 2025 4:30 pm
That is exactly why I recently purchased the Bambu Labs P1S/AMS combo. It has a feature that allow the top layers (things like numbers, lines, etc.) to be "painted" on. Previously - I would need to split the part into several bodies - one for each color, and then import these bodies separately to my FlashPrint slicer and assign a different color to each body. My Flashforge Creator 3 has dual independent extruders, so one for each color.
My main problem has always been the difficulty in aligning the two bodies for 2-color printing. Supposedly this is much easier to accomplish with the Bambu Labs P1S/AMS using their slicer. I haven't had time to get it set up yet, but do look forward to using it soon.
Here is a sample print showing my normal process for 2-color 3D prints.
Here is an example showing the "protractor" I posted above. I still have the same problem with the separate bodies (stl files) not registering correctly when imported to the slicer - so lots of time spent fiddling around getting the numbers and backer aligned.
Hopefully when I get the Bambu Labs P1S up and running, this process will be greatly simplified.
Willdamnit
adbuch wrote: Thu Mar 13, 2025 3:58 am Here is an example showing the "protractor" I posted above. I still have the same problem with the separate bodies (stl files) not registering correctly when imported to the slicer - so lots of time spent fiddling around getting the numbers and backer aligned.
I'm not sure if your aware in Bambu studio you can paint and you won't have to separate these items. Thanks for all the info and the protector files
Willdamnit
Joe Jones wrote: Tue Mar 11, 2025 10:15 am Or use one of these. Mount it where you can see the display.
I use that style currently , I just thought it would be cool the create something mounted to the brake.
Willdamnit
You'll like the slicer from Bambu you can see it from the Bambu handy app on your phone with a good Internet connection, also you can stop restart or repeat a current file or a past file and the and will be seen in the app.
Willdamnit wrote: Fri Mar 14, 2025 7:33 pm
Yes - I am aware of this. That is one of the main reasons I purchased the new (yet to be used) Bambu Labs P1S AMD. But thanks for reiterating that in case others reading this thread may have missed it.
Willdamnit wrote: Fri Mar 14, 2025 7:37 pm
I very much agree! It's way "cooler" to create your own design that to simply spend the money on a store bought item. It offers a great challenge/learning experience with the knowledge gained useful for applying to other future projects.
Willdamnit wrote: Fri Mar 14, 2025 7:40 pm
I probably won't be running my printers from my phone, but thanks for that information!
Return to “Metal Bending, Rolling, Notching, Drilling, Saw Cutting”
