Adding a bending gauge
I wanting to add a bending gauge. I've 3d printed a part I've started designing I've looked for something similar but all my searches came up with external gauges which what I'm not looking for. I use a digital gauge but I'd like to add one either side for quick bends.
Thanks any help or insight would be appreciated.
Re: Adding a bending gauge
Pretty cool. Would be slick if you could 3d print the numbers for the angles into that part. Could then use a white paint marker to highlight the numbers.
I'm currently working on the model in fusion. I'm 3d printing it with an indicator and number when I have a working concept I'll make the frame from metal then make the dial 3d printed.05Duramax wrote: Sun Mar 09, 2025 7:17 pm Pretty cool. Would be slick if you could 3d print the numbers for the angles into that part. Could then use a white paint marker to highlight the numbers.
This is one that might work for your application with a few modifications.
Here is the step file you can download from my Google Drive. Fusion 360 will open this file directly for editing, printing, etc.
https://drive.google.com/file/d/1B6gQ9r ... sp=sharing
- Joe Jones
Create a cable device that will let you see the degrees of bend by viewing a wall mounted indicator. Scale the components as desired.
- Joe Jones
Or use one of these. Mount it where you can see the display.
- Joe Jones
I use these to keep it SIMPLE.
Mount one to each side of the brake.
So many great ideas! Interested to see what you end up doing, please post back.
If you want to have the numbers printed on the gauge in a different color you can put a pause in the G-code and switch filaments. I did that some time back on a dial I printed. Using the preview in the slicer program to move to the transition of the start of the number print and put a pause there and change the filament color. Resume the printing to complete.
That would be pretty cool, I didn’t realize that was possible!acourtjester wrote: Wed Mar 12, 2025 11:54 am If you want to have the numbers printed on the gauge in a different color you can put a pause in the G-code and switch filaments. I did that some time back on a dial I printed. Using the preview in the slicer program to move to the transition of the start of the number print and put a pause there and change the filament color. Resume the printing to complete.
- Joe Jones
I think the Starrett magnetic mount gauges are the K.I.S.S. solution.
That is the plan the Bambu p1s paire with an Ams.acourtjester wrote: Wed Mar 12, 2025 11:54 am If you want to have the numbers printed on the gauge in a different color you can put a pause in the G-code and switch filaments. I did that some time back on a dial I printed. Using the preview in the slicer program to move to the transition of the start of the number print and put a pause there and change the filament color. Resume the printing to complete.
That is exactly why I recently purchased the Bambu Labs P1S/AMS combo. It has a feature that allow the top layers (things like numbers, lines, etc.) to be "painted" on. Previously - I would need to split the part into several bodies - one for each color, and then import these bodies separately to my FlashPrint slicer and assign a different color to each body. My Flashforge Creator 3 has dual independent extruders, so one for each color.Willdamnit wrote: Wed Mar 12, 2025 4:30 pmThat is the plan the Bambu p1s paire with an Ams.acourtjester wrote: Wed Mar 12, 2025 11:54 am If you want to have the numbers printed on the gauge in a different color you can put a pause in the G-code and switch filaments. I did that some time back on a dial I printed. Using the preview in the slicer program to move to the transition of the start of the number print and put a pause there and change the filament color. Resume the printing to complete.
My main problem has always been the difficulty in aligning the two bodies for 2-color printing. Supposedly this is much easier to accomplish with the Bambu Labs P1S/AMS using their slicer. I haven't had time to get it set up yet, but do look forward to using it soon.
Here is a sample print showing my normal process for 2-color 3D prints.
Here is an example showing the "protractor" I posted above. I still have the same problem with the separate bodies (stl files) not registering correctly when imported to the slicer - so lots of time spent fiddling around getting the numbers and backer aligned.
Hopefully when I get the Bambu Labs P1S up and running, this process will be greatly simplified.
I'm not sure if your aware in Bambu studio you can paint and you won't have to separate these items. Thanks for all the info and the protector filesadbuch wrote: Thu Mar 13, 2025 3:58 am Here is an example showing the "protractor" I posted above. I still have the same problem with the separate bodies (stl files) not registering correctly when imported to the slicer - so lots of time spent fiddling around getting the numbers and backer aligned.
I use that style currently , I just thought it would be cool the create something mounted to the brake.Joe Jones wrote: Tue Mar 11, 2025 10:15 am Or use one of these. Mount it where you can see the display.
You'll like the slicer from Bambu you can see it from the Bambu handy app on your phone with a good Internet connection, also you can stop restart or repeat a current file or a past file and the and will be seen in the app.adbuch wrote: Thu Mar 13, 2025 3:58 am Here is an example showing the "protractor" I posted above. I still have the same problem with the separate bodies (stl files) not registering correctly when imported to the slicer - so lots of time spent fiddling around getting the numbers and backer aligned.
Yes - I am aware of this. That is one of the main reasons I purchased the new (yet to be used) Bambu Labs P1S AMD. But thanks for reiterating that in case others reading this thread may have missed it.Willdamnit wrote: Fri Mar 14, 2025 7:33 pmI'm not sure if your aware in Bambu studio you can paint and you won't have to separate these items. Thanks for all the info and the protector filesadbuch wrote: Thu Mar 13, 2025 3:58 am Here is an example showing the "protractor" I posted above. I still have the same problem with the separate bodies (stl files) not registering correctly when imported to the slicer - so lots of time spent fiddling around getting the numbers and backer aligned.
I very much agree! It's way "cooler" to create your own design that to simply spend the money on a store bought item. It offers a great challenge/learning experience with the knowledge gained useful for applying to other future projects.Willdamnit wrote: Fri Mar 14, 2025 7:37 pmI use that style currently , I just thought it would be cool the create something mounted to the brake.Joe Jones wrote: Tue Mar 11, 2025 10:15 am Or use one of these. Mount it where you can see the display.
I probably won't be running my printers from my phone, but thanks for that information!Willdamnit wrote: Fri Mar 14, 2025 7:40 pmYou'll like the slicer from Bambu you can see it from the Bambu handy app on your phone with a good Internet connection, also you can stop restart or repeat a current file or a past file and the and will be seen in the app.adbuch wrote: Thu Mar 13, 2025 3:58 am Here is an example showing the "protractor" I posted above. I still have the same problem with the separate bodies (stl files) not registering correctly when imported to the slicer - so lots of time spent fiddling around getting the numbers and backer aligned.
