Newbie Question
Newbie Question
Forgive me ahead of time for my lack of knowledge. I do not have internet in my garage so I am curious if I purchase or download a file design on my laptop inside my house, can I save it to a flashdrive and then pull the file from my flashdrive on the computer in my garage that is with my plasma table and it wont mess up the file?
Re: Newbie Question
Work fine for me been doing that for years
Lots of files to download from here for you to use too.
- tnbndr
Re: Newbie Question
That's how I did it for 10 years. In fact when I bought my table the manufacturer recommended that I don't hook the computer to wi-fi or internet as simple updates to windows or drivers could screw things up. Thumb drive back and forth worked fine.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
Re: Newbie Question
Great thanks guys
i alreday tried to download one of the files here and screwed it up lol ugh the learning curve will be steep for me
Re: Newbie Question
What went wrong??? I do all the planning in the house and only move the G-code to the cutting PC.
Re: Newbie Question
somehow the way i saved it, it tries to open through adobe and my computers says its no supported so anytime I open or try to save it goes straight to that error message
Re: Newbie Question
acrobat I mean not adobe
Re: Newbie Question
If you are saving g-code to your thumb drive, then you should not have to open it. Just copy the file from your thumb drive to your shop computer and load it into your control software for your table.
Re: Newbie Question
Acrobat would normally be used to view pdf files. Your g-code would more likely be a file that could be read with a text editor.
Re: Newbie Question
Thank you
Re: Newbie Question
In windows you can use notepad or notepad++ as David said are Text editors. you can look at or edit G-code with them. With notepad++ you can have many open at the same time with tabs on the top with their names to switch between easily to see or compare each.
You need to close each individually as they will stay in Notepad++ if you close it as a whole.
Re: Newbie Question
Also - Notepad and some of the other editors will not recognize a g-code file as text. If you change your file type to "All files" then it will show up on the list when you try to open it with Notepad, etc.
Re: Newbie Question
Ok thank you! A lot of that is way over my head but that did lead me down a path that I think i got some stuff fixed. Im going to check today
- Joe Jones
Re: Newbie Question
Where are you located? I like to help people IN PERSON whenever possible.Mustangranch22 wrote: Fri Jan 24, 2025 9:21 am Ok thank you! A lot of that is way over my head but that did lead me down a path that I think i got some stuff fixed. Im going to check today
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Re: Newbie Question
No need to share your location. We can provide all the help you might need right here at the forum. I personally would not recommend giving out your location and/or address to a stranger on a forum. Just asking for trouble there. Most folks feel the same.Mustangranch22 wrote: Fri Jan 24, 2025 9:21 am Ok thank you! A lot of that is way over my head but that did lead me down a path that I think i got some stuff fixed. Im going to check today
