snapping parts to center and aligning parts
Fastyankee
Post by Fastyankee »
I'm struggling with centering parts and snapping parts to center and aligning parts . see photo.
AJ
irondeuces@gmail.com
Pulmax
5x10 Star Lab plasma, scribe, pipe cutter
60 ton 53” press brake
JD2 tube bender
Hulk Tube bender
Slip roll 3/16th capacity
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Re: snapping parts to center and aligning parts
Andrew - I really can't tell much from your photo. Perhaps share your file that you are working with along with what you are trying to accomplish and I will have a look.
Joe Jones
Post by Joe Jones »
If you are trying to snap that tab to the center of the top edge, you must first use the SMOOTH tool and a small value to REMOVE extra nodes.
Select the main shape.
Type [h] [.005] [ENTER]
Now place the tab at the center.
[m]ove [m]idpoint (Click on the midpoint of the bottom flat edge of the tab)
[m]idpoint (click on the top edge of the main panel)
The tab will be place at the center of that edge.
Fastyankee wrote: Tue Nov 12, 2024 10:48 am I'm struggling with centering parts and snapping parts to center and aligning parts . see photo.
Joe Jones
Post by Joe Jones »
You cannot snap to the midpoint of a line that has more than TWO nodes. You must first eliminate the excess nodes using the SMOOTH command.
