Line Laser Pro
*Fits either 1-3/8" or 1-3/4" torch bodies
*Powerful 200mw lasers
*Easily calibrate
*Flipable to allow different alignments
*Plugs into CommandCNC Aux outputs or Flashcut Aux output power block
*Create on screen button with CommandCNC
*Easy plate alignment
Check it out here
https://starlabparts.com/ols/products/l ... wermax-125
Find the edge of your material easily with the Star Lab Laser Pointer!
Torch mounted laser pointer features
*Easy twist focus
*Slot for accurate placement on torch gear rack
*Easily clamps to any torch 1-3/8" body
*Has 4' lead with x2 AA battery case
*1.25" distance from torch center to laser center
CommandCNC users there is a firmware update for laser pointer center that has a laser pointer offset setting in the manual section.
https://starlabparts.com/ols/products/t ... er-pointer
2 new lasers for CNC Plasma machines
Questions, information, project pics and more relating to plate markers, engravers, and scribes.
1 post
• Page 1 of 1
- BTA Plasma
1 post
• Page 1 of 1
Return to “Plate Markers, & Air Scribes”
Jump to
- ↳ Introduce Yourself
- ↳ Categorized DXF & SVG Library
- GENERAL FORUMS
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- PLASMA CUTTER FORUMS
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FlashCut CNC Forum
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Star-Lab CNC Forum
- ↳ Tracker CNC Forum
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- METAL FINISHING FORUMS
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
