2 new lasers for CNC Plasma machines
BTA Plasma
Post by BTA Plasma »
Line Laser Pro
*Fits either 1-3/8" or 1-3/4" torch bodies
*Powerful 200mw lasers
*Easily calibrate
*Flipable to allow different alignments
*Plugs into CommandCNC Aux outputs or Flashcut Aux output power block
*Create on screen button with CommandCNC
*Easy plate alignment
Check it out here
https://starlabparts.com/ols/products/l ... wermax-125
Find the edge of your material easily with the Star Lab Laser Pointer!
Torch mounted laser pointer features
*Easy twist focus
*Slot for accurate placement on torch gear rack
*Easily clamps to any torch 1-3/8" body
*Has 4' lead with x2 AA battery case
*1.25" distance from torch center to laser center
CommandCNC users there is a firmware update for laser pointer center that has a laser pointer offset setting in the manual section.
https://starlabparts.com/ols/products/t ... er-pointer
If Matt is using this profile he is one of the OGs of Plasma. If not then a technician. We make the worlds fastest and largest CNC plasma tables up to 10x40. www.StarLabCNC.com :Like Check out our Facebook page where we update frequently. https://m.facebook.com/StarLabcnc/
Return to “Plate Markers, & Air Scribes”
