Plasma Cutting Post processor for Fusion 360
Linux CNC - Plasmac related questions, tips and topics can be posted here
wiltshire_chris
Post by wiltshire_chris »
Me again. What post processor should I use with F360? When I select a Linux one it says its not for plasma cutting.
Rodw
Re: Post processor
Post by Rodw »
I use Sheetcam with F360. There is a F360 post on the linuxcnc forum somewhere.
My workflow is to
flatten the part (if sheetmetal)
Select the flattened part annd create a new sketch. don't do anything in the sketch
Now right click on the sketch in the tree and save as DXF.
OPen in sheetcam and set up the job
Try it with the sheetcam demo with a simple part so the 180 line thrshold is not exceeded.
Sheetcam runs on both Windows and Linux. I do my layouts in windows in my office and save direct to the machine's nc_files folder.
Then a Load Latest custom button in QTplasmac loads it with one mouse click. Check the QTP docs on this
wiltshire_chris
Re: Post processor
Rodw wrote: Mon Feb 06, 2023 4:22 pm I use Sheetcam with F360. There is a F360 post on the linuxcnc forum somewhere.
My workflow is to
I watched a few YouTube videos and it looks good, I spent the next 2 hours trying to download it on linux and have now given in on it. I can't believe it is so hard to get this table to work
Re: Plasma Cutting Post processor for Fusion 360
Keep with it you will make it, there are posts here with good info to help you get through.
https://plasmaspider.com/viewtopic.php?f=203&t=35008
Rodw
Re: Post processor
Post by Rodw »
wiltshire_chris wrote: Tue Feb 07, 2023 4:33 pm I watched a few YouTube videos and it looks good, I spent the next 2 hours trying to download it on linux and have now given in on it. I can't believe it is so hard to get this table to work
It should not be hard to download. Maybe your internet is a bit flakey. You could use windows and take it to linux via a thumb drive.
wiltshire_chris
internet seems fine, I couldn't find the box to tick that makes it exactable?
Rodw
Post by Rodw »
right click on the file, properties and there is a tab for permisssions, clcik on execute
wiltshire_chris
Rodw wrote: Tue Feb 07, 2023 8:22 pm right click on the file, properties and there is a tab for permisssions, clcik on execute
There is no box to tick for execute
Rodw
Post by Rodw »
What about allow this file to run as program?
Screenshot 2023-02-08 6.43.35 PM.png (49.74 KiB) Viewed 5682 times
I'm not often at a linux box and if i do I don't have a GUI.
I had to install a file browser just to show you this.
It might look a bit different on your system
Return to “Linux CNC - Plasmac”
