Because all the CommandCNC systems come with an RS485 bus (4PportHhub) you can add:
- RS485 serial port to Hyperherm to control cut current and air pressure dynamically form code
- Tethered PN200 jog pendant
- New, ISS-05 Intelligent Spindle Sneed with "No-Stall" torque sensing for driving 3 to 10hp VFD and spindles
- Program load settings for the DTHC 5 modules
- Testing of attached devices for troubleshooting
Looking at the accessories you can add:
- Feather Touch Ohmic sensor.
- Super Z II Full function Z axis with floting torch holder and sensors for mechanical touch off and limnits
- Optional Braekaway torch holder on SUper Z IIwith inductive sensor for ESTOP
- [*A plug-in module with 4 additional 10A relays controlled form the console or from code.
- A low Profile toolsetter (LPTS) for use with the semi-auto tool change in ourCommadnCNC Router profiles
Probably most exciting is our just released RC400 Remote Console Wireless tablet . Its a lot more than just a Jog pendant. You can use it to Setup the machine using multiple jog speeds and jog types. You can Home and zero all of the axis . Do a manual touch off (or a tool set in router mode) . Switching to RUN mode you can search and load g-code cut files and Run, pause and stop code . See code scrolling . Full DTcontrol. All without ever going back to the keyboard or monitor .
The RC400 runs with our Plasma, router or Ox y-fuel Profiles in CommadnCNC and uses high speed WIFI for range and reliability. Across the tabl;e or across the room it give s you control in your hand.
https://www.candcnc.net/store-home/rc40 ... ss-tablet/
