Options for a CommadnCNC system
Post by tcaudle »
When looking at controls and doing a retrofit or a new build some of the things to consider are the accessories and options you can odd to the system , now or later;
Because all the CommandCNC systems come with an RS485 bus (4PportHhub) you can add:
  • RS485 serial port to Hyperherm to control cut current and air pressure dynamically form code
  • Tethered PN200 jog pendant
  • New, ISS-05 Intelligent Spindle Sneed with "No-Stall" torque sensing for driving 3 to 10hp VFD and spindles
  • Program load settings for the DTHC 5 modules
  • Testing of attached devices for troubleshooting
The base system has 16 opto isolated Inputs, 2 switched AC outlets and support for 5 axis of drivers (6 on some systems)
Looking at the accessories you can add:
  • Feather Touch Ohmic sensor.
  • Super Z II Full function Z axis with floting torch holder and sensors for mechanical touch off and limnits
  • Optional Braekaway torch holder on SUper Z IIwith inductive sensor for ESTOP
  • [*A plug-in module with 4 additional 10A relays controlled form the console or from code.
  • A low Profile toolsetter (LPTS) for use with the semi-auto tool change in ourCommadnCNC Router profiles
The Semi-auto toolchange for router/spindle is part of the CommandCNC router profiles and comes with tool change POSTS for ShetCAM and for Vectric products like VCarve Pro.
Probably most exciting is our just released RC400 Remote Console Wireless tablet . Its a lot more than just a Jog pendant. You can use it to Setup the machine using multiple jog speeds and jog types. You can Home and zero all of the axis . Do a manual touch off (or a tool set in router mode) . Switching to RUN mode you can search and load g-code cut files and Run, pause and stop code . See code scrolling . Full DTcontrol. All without ever going back to the keyboard or monitor .
The RC400 runs with our Plasma, router or Ox y-fuel Profiles in CommadnCNC and uses high speed WIFI for range and reliability. Across the tabl;e or across the room it give s you control in your hand.
https://www.candcnc.net/store-home/rc40 ... ss-tablet/
RC400QuickLook.pdf
Re: Options for a CommadnCNC system
That wireless tablet is the coolest accessory I have come across in a long time! Very impressive Tom :Like
Return to “CandCNC Forum”
