0-22 Error on Powermax 65
Discussion on 0-30 fault codes
ColoradoWayne
Post by ColoradoWayne »
We have had our Hypertherm Powermax 65 since we started cutting steel almost 9 years ago. It has worked nearly flawlessly in all that time, even though it has been pushed pretty hard from time to time. It came to a dead stop recently. Showing a 0-22 error which I could find very little information on, rather than turn on the gas. Luckily the fine people at Hypertherm quickly and easily diagnosed the problem, provided a work around and gave me the part number I needed to order. It was a simple air pressure switch gone bad. The switch is now replaced along with a new air filter. Just want to give accolades to the folks at Hypertherm for their help and direction. Salute!
Wayne
LDR Motion Systems 4 x 4 water table
Re: 0-22 Error on PMX 65
Good feedback thanks.
weldguy
Post by weldguy »
That's great, thanks for the info :Like :Like
Bern
Re: 0-22 Error on Powermax 65
Post by Bern »
Hi Wayne
I have the same problem now . Can I just bridge the pressure switch for a quik fix until I get a new switch.
Thanks Bernard
Return to “0-22 Fault Code”
