Curious if any of you guys with some of this lower cost lower powered laser experience have found a unit that will cut .080" steel. Doesn't need to cut a lot of it, I just want to notch 1.25" diameter .080" wall steel tubing from time to time.
If I could find a lower cost laser that would cut it I would try my hand at building a cnc rotary tube notching unit. Currently notching everything by hand which is fine for the amount I do but this is a project I would like to take on, just need a laser I can afford that will do it.
Laser that will cut .080" steel
Tracker CNC 4x4
- cstroke
Re: Laser that will cut .080" steel
Small footprint lasers I've seen a few that are around 80k..
Here's a link to a manufacturer I've seen around.
Probably best to join a fiber laser group on facebook and watch the posts.
https://www.gweikecnc.com/fiberlaser/?g ... yIEALw_wcB
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
- rdj357
There are a few options that won't completely break the bank that will cut in that range.
https://lightobject.com/laser-machine/c ... l-cutting/
Robert Johnson
PlasmaCAM GURU & Instructor
Thanks for the links guys, going to check those out
Tracker CNC 4x4
So I checked out the links and see they are all complete machines, I was looking more for just the laser and I would build the rest. I just saw these smaller format laser modules folks are mounting to there tables more for engraving and stuff and was curious if they had something similar with enough power to cut .080" steel.
Tracker CNC 4x4
- rdj357
Cutting metal with a laser requires proper height control and assist gas. I'm sure it's not impossible to build something yourself but I dare say, without a lot of research, trial, and error, you're in for heartache.
Robert Johnson
10-4 Robert, I appreciate everyone's input.
Tracker CNC 4x4
- Joe Jones
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
