Laser that will cut .080" steel
Topics related to laser engravers and laser cutters.
DieselFumes
Post by DieselFumes »
Curious if any of you guys with some of this lower cost lower powered laser experience have found a unit that will cut .080" steel. Doesn't need to cut a lot of it, I just want to notch 1.25" diameter .080" wall steel tubing from time to time.
If I could find a lower cost laser that would cut it I would try my hand at building a cnc rotary tube notching unit. Currently notching everything by hand which is fine for the amount I do but this is a project I would like to take on, just need a laser I can afford that will do it.
Tracker CNC 4x4
cstroke
Re: Laser that will cut .080" steel
Post by cstroke »
Small footprint lasers I've seen a few that are around 80k..
Here's a link to a manufacturer I've seen around.
Probably best to join a fiber laser group on facebook and watch the posts.
https://www.gweikecnc.com/fiberlaser/?g ... yIEALw_wcB
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
rdj357
Post by rdj357 »
There are a few options that won't completely break the bank that will cut in that range.
https://lightobject.com/laser-machine/c ... l-cutting/
Robert Johnson
PlasmaCAM GURU & Instructor
DieselFumes
Thanks for the links guys, going to check those out :Like
Tracker CNC 4x4
DieselFumes
So I checked out the links and see they are all complete machines, I was looking more for just the laser and I would build the rest. I just saw these smaller format laser modules folks are mounting to there tables more for engraving and stuff and was curious if they had something similar with enough power to cut .080" steel.
Tracker CNC 4x4
rdj357
Post by rdj357 »
Cutting metal with a laser requires proper height control and assist gas. I'm sure it's not impossible to build something yourself but I dare say, without a lot of research, trial, and error, you're in for heartache.
Robert Johnson
DieselFumes
10-4 Robert, I appreciate everyone's input.
Tracker CNC 4x4
Joe Jones
Post by Joe Jones »
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
Return to “Laser Engravers & Cutters”
