Looking for some sign mounting tips.
JeepGuy
Post by JeepGuy »
Making a sign thats 7 seperate letters and a logo, the customer wants them mounted about 1.5" off the wall, its drywall , whats the best/easiest way to make that happen?
Re: Looking for some sign mounting tips.
Will this be a permanent mounting or does the customer want them removable? For semi-permanent, I would think that drywall anchors would work. Then attach your standoffs or whatever to the anchors.
djreiswig
Post by djreiswig »
How big are the pieces? If they're not too heavy, some kind of 3M tape might work. You would have to make standoffs of some sort.
Joe Jones
Post by Joe Jones »
Spot weld small metal brackets to the rear of the letters. Illustration is NOT drawn to proportion. Concept Drawing ONLY.
INSURE that metal brackets for each letter or shape can support the weight without bending down!
Position brackets so they CANNOT be seen looking straight at the sign. Letters 1-1/2" off of the wall means the brackets WILL be seen when looking at the letters from an angle. Paint the brackets the same color as the wall to make them less obvious.
Lay out the letters and LOGO on a large sheet of paper (white paper or butcher paper, etc.) Align the entire design on the paper.
Mark the top center radius of each bracket slot on the paper.
Tape paper to wall LEVEL. Poke though paper to mark spots on wall.
Use small machine thread drywall anchors. Put anchors through drywall, pinch down anchors on rear side.
Back threaded screws out a bit, hang the letters and retighten them.
Avoid wall studs if possible. Use a wood screw in place of any anchor that hits a wall stud.
PlasmaCam 4x4, Samson 510 table, Go Torch, + more
AD-AH-AM-AN-3D-CS-MU-PC - Upgrades
X-TOOL D1 PRO (x 4) F1, S1 (x3), P2 (x2), F1 ULTRA (x2) with conveyors, M1 ULTRA (x2) + accs.
50 Watt GALVO fiber
SwiftShape 3-in-1 machine
CreatBot D600 PRO
Stratasys Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
DieselFumes
Post by DieselFumes »
Drywall would be a but if a tough on with it being raised off 1.5". Joe's idea above seems like a good solution.
Tracker CNC 4x4
Joe Jones
Post by Joe Jones »
DieselFumes wrote: Fri May 06, 2022 10:21 am Drywall would be a but if a tough on with it being raised off 1.5". Joe's idea above seems like a good solution.
Thank you for the compliment! :Yay
You can either make the brackets out of thicker metal and weld them to the rear of the letters, or make them out of thinner metal, and give them some side flanges to resist bending down under the weight of the metal they support.
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
Joe Jones
Post by Joe Jones »
OR you could just BUY curtain rod brackets and modify them to suit your needs. These brackets allow you to ADJUST the distance from the wall. They will also allow you to compensate for a wall that is not completely FLAT or perfectly vertical. Cut off the hook end below the screw, bend the remaining tab to 90 degrees, tack weld it to the rear of the letter, OR use something like FAST DRY JB WELD COMPOUND if you do not want to weld them, or you have already painted or powder coated them, or chrome plated them, and welding is no longer an option.
Make sure the JB WELD COMPOUND is on the METAL LOAD, and not only bonded to a coat of paint or something that can flake off of the load under the weight.
DO NOT cut off the metal below the key slot. this will INCREASE the leverage the letter has to pull the anchor out of the wall, and you do not want that.
WARNING! Before QUOTING this job, count the number of brackets you will need. These brackets are NOT CHEAP! and JB WELD COMPOUND is 'SPENSIVE, LUCY! :lol:
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
Joe Jones
Post by Joe Jones »
djreiswig wrote: Thu May 05, 2022 4:57 pm How big are the pieces? If they're not too heavy, some kind of 3M tape might work. You would have to make standoffs of some sort.
Adhesive tape ONLY works when the load is flush with the wall, and you use a LOT of adhesive tape. Brackets that hold the load AWAY FROM the wall create LEVERAGE, and as the tape heats up and succumbs to humidity and such, the letters WILL fall off of the wall.
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
djreiswig
Post by djreiswig »
Joe Jones wrote: Fri May 06, 2022 2:20 pm
See my first question? If the letters are a couple of inches tall, then I don't see why tape wouldn't work. Especially if they are aluminum. A lot of missing details...
Joe Jones
Post by Joe Jones »
Lettering this 2 inches tall would be not be mounted an inch and a half off of the wall surface.
Jeep guy, tell us a little more about your project. I am assuming that you are going to create letters and a logo that mount on a wall, such as behind a receptionist desk, or outside along the wall as you walk into an entry or perhaps in a lobby. I am guessing that the letters are between nine and 12 inches tall and the logo is probably 18 to 24 inches in diameter. How far off am I?
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
djreiswig
Post by djreiswig »
Joe Jones wrote: Fri May 06, 2022 7:22 pm I am guessing that the letters are between nine and 12 inches tall and the logo is probably 18 to 24 inches in diameter.
Joe, can you tell us what the sign is gonna say? It's 7 letters.
Maybe it's J E E P G U Y
Joe Jones
Post by Joe Jones »
djreiswig wrote: Fri May 06, 2022 11:59 pm
JeepGuy wrote: Thu May 05, 2022 4:36 pm Making a sign thats 7 seperate letters and a logo, the customer wants them mounted about 1.5" off the wall, its drywall , whats the best/easiest way to make that happen?
Unless he has a split personality, I am guessing that he is doing this for someone else. :HaHa
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
djreiswig
Post by djreiswig »
Gotcha. But since you have figured out what the sign is gonna look like, I figured you might wanna share what it's gonna say.
Joe Jones
Post by Joe Jones »
djreiswig wrote: Sat May 07, 2022 7:16 am Gotcha. But since you have figured out what the sign is gonna look like, I figured you might wanna share what it's gonna say.
BROTHEL :Yay
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
Joe Jones
Post by Joe Jones »
I figure it will be something like this ...
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
djreiswig
Post by djreiswig »
Joe Jones wrote: Sat May 07, 2022 8:20 am
BROTHEL :Yay
:shock:
JeepGuy
Post by JeepGuy »
Joe your pretty close, in a conference room. Space available is 4'. This is the name and logo.
Drywall anchors are "your friend".
Joe Jones
Post by Joe Jones »
adbuch wrote: Sat May 07, 2022 4:48 pm Drywall anchors are "your friend".
I absolutely HATE sheetrock! It is cheap to install, and easy to repair, but a total PITA to work with. When I finish off the four guest bedroom suites on the second floor of the Frankenbarn, the walls will all be 1/2" quality grade plywood with some durable exterior surface applied.
50 Watt GALVO fiber
CreatBot D600 PRO
BIGREP Studio Gen 2
MODIX Big Meter
ROKCRLER
Post by ROKCRLER »
Heres another cool "french cleat" mount
Found on facebook, it wouldnt let me put the link...
A couple spotwelds and done...
4x8 Dynatorch
PM85
~Mo~
Plasma-art
Post by Plasma-art »
ROKCRLER wrote: Sun Oct 30, 2022 2:13 pm Heres another cool "french cleat" mount
I really like that mounting system.
They are prety expensive over here and but easy to make a bunch..
Might be worth to get a set of press dies made to bend them in one go.
ROKCRLER
Post by ROKCRLER »
Plasma-art wrote: Sun Oct 30, 2022 3:14 pm
I was thinking the same thing, im making a press die to make my 'trick tabs' for mounting panels on rollcages.
4x8 Dynatorch
PM85
~Mo~
A little bit off the original topic, but for mounting very light weight pictures on interior walls perhaps these could be 3D printed. Just a thought.
