Swirl mark on electrode and shield.
DannyD
Post by DannyD »
Hi, looking for advice re some weird wear I'm getting on my consumables.
I have an 45XP setup with machine torch on a Crossfire Pro.
Thinking about the swirl of a burnmark on shield and electrode in the pics.
Eventually this will burn right through the shield, just didn't have one of those handy.
What might be causing this?
Any thoughts?
D
robertspark
Re: Swirl mark on electrode and shield.
Post by robertspark »
check swirl ring is clean, all holes are open, no burs.
check o-ring.
How about air containations, how good is you filtering of the air supply.
weldguy
Post by weldguy »
That will be contamination in your air supply. It is being burned up in the plasma arc and leaving those deposits. What are you using for air filtration?
