nest two object to share one cut?
lancepr
Post by lancepr »
If I want to cut two rectangles and share one side(cut) how would I do that in sheet cam?
The first rectangle should cut all 4 sides, then the second cut should just cut 3 sides.
Seems simple enough, but I have been trying to do this for the past hour and can not get anything to work
beefy
Re: nest two object to share one cut?
Post by beefy »
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
djreiswig
Post by djreiswig »
Make sure you adjust for the kerf on the shared edge on the second part.
lancepr
Post by lancepr »
I see, I was trying to do it in sheetcam, but it looks like you have to do it in the drawing app.
I was hoping to be able to duplicate say 6 squares and share cuts, but it looks like that is not possible.
Return to “SheetCam”
