I need to cut some parts that need to be bent. I have tried adding a slot on the "bend" line, but when I go to simulate the g-code run it consistently ignores my slots. Do I need to do the parts as a "sheet metal" design??
f
fusion 360 - manufacture and cutting
Re: fusion 360 - manufacture and cutting
By simulate do you mean in Fusion 360 or in Mach or you table software Or SheetCam.
More info is needed for a clear answer, remember you are the only person in the room your asking someone remotely to know what is going on. No Magic just the facts
Your slots need to be wider, they must be your kerf X 2 plus a little or Fusion will not read the invalid cuts.
