fusion 360 - manufacture and cutting
fairlane65
Post by fairlane65 »
I need to cut some parts that need to be bent. I have tried adding a slot on the "bend" line, but when I go to simulate the g-code run it consistently ignores my slots. Do I need to do the parts as a "sheet metal" design??
f
Re: fusion 360 - manufacture and cutting
By simulate do you mean in Fusion 360 or in Mach or you table software Or SheetCam.
More info is needed for a clear answer, remember you are the only person in the room your asking someone remotely to know what is going on. No Magic just the facts
ctgolfer1
Post by ctgolfer1 »
Your slots need to be wider, they must be your kerf X 2 plus a little or Fusion will not read the invalid cuts.
