Miller 625 xtream problems
Discussion forum for Lincoln & Miller plasma cutters
Joe243672
Post by Joe243672 »
I have an issue with miller 625 xtreme. Unit always worked well for me. I let a guy use it and it looks to me like he was cutting on a chassis with under coating on it. The torch head was completely clogged and machine just Trips the breaker now when you try and turn on. I took the case off to see what was going on and I can see one of the 4 capacitors is blown up. Anyone ever expieriance that before. Im thinking once he clogged torch up he tried to fire torch again and it just back fed right back to machine and toasted the capacitor. Also has anyone ever had any companies other then miller do repair work on these machine boards. Thanks for any info you can give
Crossfire Plasma Table
Hypertherm pm 85 cpc rs-485
Miller 252 mig
Miller dynasty 280 Tic/stick
Metabo Mag drill
various Fab equipment
4x8 precision plasma table
G5 c and cnc controls
“ the Shop “ were it all happens
weldguy
Re: Miller 625 xtream problems
Post by weldguy »
That sucks, precisely why I hate lending things out. A local Miller dealer will have a repair facility they use but it will be expensive if you are unable to replace the cap yourself. Bummer.
djreiswig
Post by djreiswig »
I'd say the guy just bought himself a plasma cutter. Too bad it doesn't work.
Return to “Lincoln & Miller Plasma Cutters”
