Why the ghost lines ? Importing to sheetcam
Sampson Jones
Post by Sampson Jones »
This is annoying aa hell . I have saved and exported in corel the following dxf,svg,cmg . I have boxed out all around the main object to see if any tiny debis shows up . Nothing but a clean object shows . Object was joined curves , grouped , saved and exported to sheetcam . When in sheetcam all theses horizonial straight lines show up . Ive had this before , but damned if Ive ever figured out what causes it .
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
mr.jake519
Re: Why the ghost lines ? Importing to sheetcam
Post by mr.jake519 »
Try selecting just your object and paste it into a new layer then export from that layer. It would rule out something being on your current drawing.
Home built 4x8
uccnc
axbb-e
gecko 201x
Neuron lite thc
beefy
Post by beefy »
If you can post some simple file where the problem exists then you stand a better chance of someone figuring out what is going on.
Lots of members now seem to either post only a description of the problem or a jpeg image.
I realise you won't want to give your designs away so can you do a "Save As" for your file and then delete the fancy arty bits. Then export and check the ghost lines are still showing up again. If so attach the file here.
I use Coreldraw and the only time I've had such problems are when the file came from somewhere else. It's amazing how much junk can be in some files. Whenever I create the file in Coreldraw myself it usually exports OK.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
Sampson Jones
The horizontal lines do not show up on the CorelDRAW work space . When viewing then same file in Inkscape they are clearly visible .
CandCNC electronics
Command Lineux
Super z 2
Sampson Jones
Here you go Beefy , The horizontal line at he top left does not show up in the workspace in Corel - not even stretching a box around it to show up the trash around the main object . When viewed in Inkscape the horizontal line . clearly shows up .
Backup_of_FIREBALL CELESTIAL MASTER170% sheet 3 of 3 ultimate master 2020.cdr
CandCNC electronics
Command Lineux
Super z 2
beefy
Post by beefy »
Hi Sampson,
I don't use Inkscape but what I did notice in Coreldraw is there's several other layers, one of which has a horizontal line in but the layer is set to invisible.
I deleted all those layers and this is the resulting file. Is it any better ?
Backup_of_FIREBALL CELESTIAL MASTER170% sheet 3 of 3 ultimate master 2020 (2).cdr
LinuxCNC
Coreldraw 2019
Sampson Jones
Thanks , but I need to know how to find this ? I've been using Corel 10 yrs and never took much time learning or understanding layers .I guess objet properties is where you start ? I f you could give a step by step on how to do this I would be grateful . Thanks
CandCNC electronics
Command Lineux
Super z 2
