Arclight Auto Tracer - Will it work with other brands of cnc tables?
Arclight Hardware discussion forum.
I am interested in using the Auto Tracer on a non-Arclight machine. I have a PlasmaCAM DHC2, a CNC Router Parts Pro4848 running with Mach3, and an Avid CNC Pro2448 running with the Centroid Acorn controller. I have not been able to find any information online as to exactly how the Arclight Auto Tracer interface works. It obviously traces a pattern and creates the corresponding vector file in dxf format. My question is how it interfaces with the cnc controller to drive the motors to do the actual trace. I will appreciate any of your input.
David Buchhauser
Arclight Dynamics Tech
Re: Arclight Auto Tracer - Will it work with other brands of cnc tables?
Post by Arclight Dynamics Tech »
The auto tracer runs off of SheetCAMs Scanything software. I am not sure what systems it is compatible with but you can find out more on the SheetCAM website. https://www.sheetcam.com/Scanything/index
Just a follow-up. I received excellent advise from Les Newell of Sheetcam and now have my Auto Tracer working perfectly.
sonbakler
Post by sonbakler »
Now thats cool! Went to Arclight website for more info and found this video. Super cool option :Like :Like
Trick Tools sells the Arclight Dynamics Auto Tracer add-on kit (as shown in the Arclight video above) for $350 plus shipping. An alternative is to purchase the Scanything software for from Les for around $50 and purchase the camera and lamp (as shown in my video above) for around $125. So total cost under $200. Mach3 is required to run the Scanything software.
cutnweld
Post by cutnweld »
How did you get it to work? Mine gummed the computer up so bad it quit working, maybe because I had a long USB cable? Got scared of it tho and never tried again. It would follow a drawn line on a piece of paper then all of a sudden take off into the rhubarb and say line lost. Tried turning the speed down to a crawl, fiddled with light settings, no go for me.
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Ermaksan Brake
The first camera I tried (pen camera from Amazon) gave very poor results and I was about ready to give up.
https://www.amazon.com/gp/product/B0066 ... UTF8&psc=1
Then Les Newell gave me some recommendations for a good camera with additional lighting. Here is my current camera and lamp.
https://www.amazon.com/gp/product/B07R4 ... UTF8&psc=1
https://www.amazon.com/gp/product/B07ZR ... UTF8&psc=1
Les also provided some excellent suggestions for setting up and calibrating the camera/software. You can read his suggestions here.
https://forum.sheetcam.com/viewtopic.php?t=8205
https://forum.sheetcam.com/viewtopic.ph ... 5&start=15
cutnweld wrote: Fri Aug 21, 2020 10:44 am maybe because I had a long USB cable? Got scared of it tho and never tried again. It would follow a drawn line on a piece of paper then all of a sudden take off into the rhubarb and say line lost. Tried turning the speed down to a crawl, fiddled with light settings, no go for me.
I started off with a shorter USB cable (about 6 ft.) for my initial testing. Once I got everything dialed in, I switched to a longer 16 ft. active USB cable so I could run it thru the cable tracks on my cnc router. I have found that Scanything works better when tracing faster - as opposed to very slow. It is also very important to have a good lighting source. I can trace templates, black lines, metal parts, wrenches, blocks of wood - just about anything you can think of. The accuracy of the resulting dxf files is very good. I can trace a round 6" diameter metal disc (1/8" thick) and achieve accuracy of within a few thousandths of the actual part dimension. This is a great setup. You probably just need to get a better camera with good lighting.
https://www.amazon.com/gp/product/B07P8 ... UTF8&psc=1
Here is the Scanything auto tracer tracing a wrench and a large plasma cut metal washer. Very good accuracy.
https://youtu.be/2O7PQdEWUyY
DavesMachineShop
Post by DavesMachineShop »
adbuch wrote: Tue Aug 18, 2020 3:39 am Just a follow-up. I received excellent advise from Les Newell of Sheetcam and now have my Auto Tracer working perfectly.
Hello Dave, i was just trying reach out to you as i have a STV CNC Plasma table that i would like to get an auto tracer added to and i dont really know where to start or what product to purchase that will get the same results it sounds like you had. i did leave a message for you with my phone number if you could respond here or give me a call id appreciate it.
thanks so much!
Hi Dave,
I did not receive a PM from you. Here is the Scanything webpage.
It will work with Mach 3, Eding CNC, or LinuxCNC. I am running mine with Mach3 with an Ethernet adapter and it works fine.
What control software does your table use?
DavesMachineShop
thanks, it uses my plasma.
DavesMachineShop
sorry i left a vm on your phone as i clicked contact and it took me to your webpage with cars so thats how i got your phone number
DavesMachineShop wrote: Mon May 03, 2021 9:31 pm sorry i left a vm on your phone as i clicked contact and it took me to your webpage with cars so thats how i got your phone number
OK. Thanks!
Return to “Arclight Dynamics”
