Arclight Auto Tracer - Will it work with other brands of cnc tables?
I am interested in using the Auto Tracer on a non-Arclight machine. I have a PlasmaCAM DHC2, a CNC Router Parts Pro4848 running with Mach3, and an Avid CNC Pro2448 running with the Centroid Acorn controller. I have not been able to find any information online as to exactly how the Arclight Auto Tracer interface works. It obviously traces a pattern and creates the corresponding vector file in dxf format. My question is how it interfaces with the cnc controller to drive the motors to do the actual trace. I will appreciate any of your input.
David Buchhauser
David Buchhauser
Re: Arclight Auto Tracer - Will it work with other brands of cnc tables?
The auto tracer runs off of SheetCAMs Scanything software. I am not sure what systems it is compatible with but you can find out more on the SheetCAM website. https://www.sheetcam.com/Scanything/index
Just a follow-up. I received excellent advise from Les Newell of Sheetcam and now have my Auto Tracer working perfectly.
Now thats cool! Went to Arclight website for more info and found this video. Super cool option
Trick Tools sells the Arclight Dynamics Auto Tracer add-on kit (as shown in the Arclight video above) for $350 plus shipping. An alternative is to purchase the Scanything software for from Les for around $50 and purchase the camera and lamp (as shown in my video above) for around $125. So total cost under $200. Mach3 is required to run the Scanything software.
How did you get it to work? Mine gummed the computer up so bad it quit working, maybe because I had a long USB cable? Got scared of it tho and never tried again. It would follow a drawn line on a piece of paper then all of a sudden take off into the rhubarb and say line lost. Tried turning the speed down to a crawl, fiddled with light settings, no go for me.
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Ermaksan Brake
10x40 lathe
2-Miller 255
Miller XMT350MPA
The first camera I tried (pen camera from Amazon) gave very poor results and I was about ready to give up.
https://www.amazon.com/gp/product/B0066 ... UTF8&psc=1 Then Les Newell gave me some recommendations for a good camera with additional lighting. Here is my current camera and lamp.
https://www.amazon.com/gp/product/B07R4 ... UTF8&psc=1 https://www.amazon.com/gp/product/B07ZR ... UTF8&psc=1 Les also provided some excellent suggestions for setting up and calibrating the camera/software. You can read his suggestions here.
https://forum.sheetcam.com/viewtopic.php?t=8205
https://forum.sheetcam.com/viewtopic.ph ... 5&start=15
I started off with a shorter USB cable (about 6 ft.) for my initial testing. Once I got everything dialed in, I switched to a longer 16 ft. active USB cable so I could run it thru the cable tracks on my cnc router. I have found that Scanything works better when tracing faster - as opposed to very slow. It is also very important to have a good lighting source. I can trace templates, black lines, metal parts, wrenches, blocks of wood - just about anything you can think of. The accuracy of the resulting dxf files is very good. I can trace a round 6" diameter metal disc (1/8" thick) and achieve accuracy of within a few thousandths of the actual part dimension. This is a great setup. You probably just need to get a better camera with good lighting.cutnweld wrote: Fri Aug 21, 2020 10:44 am maybe because I had a long USB cable? Got scared of it tho and never tried again. It would follow a drawn line on a piece of paper then all of a sudden take off into the rhubarb and say line lost. Tried turning the speed down to a crawl, fiddled with light settings, no go for me.
https://www.amazon.com/gp/product/B07P8 ... UTF8&psc=1
Here is the Scanything auto tracer tracing a wrench and a large plasma cut metal washer. Very good accuracy.
https://youtu.be/2O7PQdEWUyY
Hello Dave, i was just trying reach out to you as i have a STV CNC Plasma table that i would like to get an auto tracer added to and i dont really know where to start or what product to purchase that will get the same results it sounds like you had. i did leave a message for you with my phone number if you could respond here or give me a call id appreciate it.adbuch wrote: Tue Aug 18, 2020 3:39 am Just a follow-up. I received excellent advise from Les Newell of Sheetcam and now have my Auto Tracer working perfectly.
thanks so much!
Hi Dave,
I did not receive a PM from you. Here is the Scanything webpage.
It will work with Mach 3, Eding CNC, or LinuxCNC. I am running mine with Mach3 with an Ethernet adapter and it works fine.
What control software does your table use?
thanks, it uses my plasma.
sorry i left a vm on your phone as i clicked contact and it took me to your webpage with cars so thats how i got your phone number
OK. Thanks!DavesMachineShop wrote: Mon May 03, 2021 9:31 pm sorry i left a vm on your phone as i clicked contact and it took me to your webpage with cars so thats how i got your phone number
