Z axis - Stop on G31
Plasron
Post by Plasron »
What settings in Sheetcam would cause Mach3 to stop on line 120 G31 Z-100 F19.685
On another file it stops on line 110 G00.4000
Please help
Ron
Windows 10 64 bit laptop
Gorilla 4x4 table
Proma torch height control
Gecko mini gender changer to USB
Everlast 80 S Plasma cutter
Mach3
Inkscape
QCAD.
Re: Z axis
Ok a G31 command is looking for a Probe input signal, you did not state if the Z moved down until a safety was hit?
G0 is a move command but that line has not locations for it to go, there should be an axis name like X, Y, or Z .400
Plasron
Re: Z axis
Post by Plasron »
acourtjester wrote: Wed Feb 19, 2020 11:18 am Ok a G31 command is looking for a Probe input signal, you did not state if the Z moved down until a safety was hit?
Thanks acourtjester
Dropped the laptop we were using on the CNC machine and we are having to start from scratch on a new laptop.
I playing around with Sangit a video recording program so I can show you guys how I am doing processing etc.
hope this works
https://www.screencast.com/t/ns3UwO7X
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Plasron
Re: Z axis
Post by Plasron »
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Plasron
Re: Z axis
Post by Plasron »
Plasron wrote: Wed Feb 19, 2020 10:43 am What settings in Sheetcam would cause Mach3 to stop on line 120 G31 Z-100 F19.685
Please help
Ron
https://www.screencast.com/t/qnLsy12za
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Re: Z axis
AS I said above the G31 command is for a probe input signal, and it seen it does not get it and that is why it stops there. see attached image of the input info about the probe. Another thing I find odd is why are you raising the Z to 40" I raise mine to 1"
some other background info would help like is this a new table you are setting up, what post processor are you using.
djreiswig
Re: Z axis
Post by djreiswig »
I think it's 0.4000
Plasron
Re: Z axis
Post by Plasron »
acourtjester wrote: Wed Feb 19, 2020 10:27 pm AS I said above the G31 command is for a probe input signal, and it seen it does not get it and that is why it stops there. see attached image of the input info about the probe. Another thing I find odd is why are you raising the Z to 40" I raise mine to 1"
Thank you acourtjester
I was using the wrong processor and I just found out where to change the Z 40.000 to Z 1.5
Thank agin
Ron
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Plasron
Re: Z axis
Post by Plasron »
djreiswig wrote: Thu Feb 20, 2020 8:50 am I think it's 0.4000
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Re: Z axis - Stop on G31
Happy to help have fun Ron
Return to “SheetCam”
