Not cutting all the way through in one direction
Alabass
Post by Alabass »
Was cutting a piece last night and at times the torch wouldn't cut all the way through the material in one direction. Cutting 14 ga. mild steel with 45 amp fine cut consumables at book specs. I tried bumping the voltage up a little but it didn't help. Don't know why it only had a problem in one direction.
djreiswig
Re: Not cutting all the way through in one direction
Post by djreiswig »
Bumping volts up would raise the torch which would probably make it worse.
I would guess your cutting too high or your consumables are worn. Did you measure your cut height to verify it is correct?
robertspark
Post by robertspark »
djreiswig wrote: Sun Feb 16, 2020 7:56 pm Bumping volts up would raise the torch which would probably make it worse.
+1
raise voltage = raise torch
Lower voltage = lower torch
weldguy
Post by weldguy »
Guessing worn consumables also. Use a magnifying glass to inspect the hole in the end of your nozzle. If its not perfectly round and/or has a blow out on one side of it that's the issue I suspect. Touching the material with the nozzle or dirty moist air will cause this a lot.
Alabass
Post by Alabass »
Thanks guys. Was using fine cut consumables and the nozzle had blown out one side so the hole was not round.
