Sheetcam - Open lines - Open paths
Plasron
Post by Plasron »
My brother and I have wasted so much metal TRYING to get an American Tattered Flag, I went in Inkscape and connected all the nodes, brought up Sheetcam and went through setting up operations, inside and outside.
The picture below is what I get, notice where the lines representing the stripes in the flag is mostly empty, a test run in Mac3 cuts it like Sheetcam shows it. What am I doing wrong?
Thanks in advance
Ron
Windows 10 64 bit laptop
Gorilla 4x4 table
Proma torch height control
Gecko mini gender changer to USB
Everlast 80 S Plasma cutter
Mach3
Inkscape
QCAD.
WyoGreen
Re: Sheetcam
Post by WyoGreen »
The error code you are getting indicates you have some open lines, and some lines are either too close together or too small to machine. You need to be aware of your plasma kerf width when you design something. Looking at your picture, it appears there are a lot of bits and pieces of lines on your stripes.
There are a lot of tattered flags files on this site, some better than others. Do a search and take a look at a few and see how they handled the stripes.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
Plasron
Re: Sheetcam
Post by Plasron »
WyoGreen wrote: Tue Jan 07, 2020 12:24 pm The error code you are getting indicates you have some open lines, and some lines are either too close together or too small to machine. You need to be aware of your plasma kerf width when you design something. Looking at your picture, it appears there are a lot of bits and pieces of lines on your stripes.
Thank You WyoGreen
I wish I had never got involved with Plasma cutting, I don’t know how much more money my brother is willing to spend before he decides this stuff is way over our heads, I’m ready to give up on this waste of time and money hobby.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
djreiswig
Re: Sheetcam
Post by djreiswig »
Most hobbies cost money. We all experienced the learning curve when we started. I still have a duh moment every so often.
Stick with it. It gets easier.
TJS
Re: Sheetcam
Post by TJS »
Where did you download the tattered flag from. I downloaded a regular flag from here. One thing is that I did differently is NO OFFSET and make it all one layer. Try it and see what happens. YMMV.
Re: Sheetcam
If you are cutting a line you use the no offset and they need to be cut all as one layer, They only have a start and end so if you use outside or inside they are closed start and end is the same place. To separate lines from the others use the contour function in Sheetcam to create a layer with all lines.
Plasron
Re: Sheetcam
Post by Plasron »
Thanks for the encouragement guys
I think I got one of the tattered flags here, I never thought of cutting on the lines, NO Offset, I will give that a try, do I do a lead in and lead out or no lead in and out.
Thanks again for the encouragement
Ron
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
djreiswig
Re: Sheetcam
Post by djreiswig »
If it's just a line, you don't want leads.
Plasron
Re: Sheetcam
Post by Plasron »
djreiswig wrote: Tue Jan 07, 2020 6:46 pm If it's just a line, you don't want leads.
Thanks djreiswig
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Plasron
Re: Sheetcam
Post by Plasron »
Good news, cutting on the line (no offset) worked great, some of the cuts didn't cuts left chads, but that was because of dirty files, If I go back and connect the lines and clean up the files there shouldn't be any problems with cutting.
Thanks so much for all you guys help, Greatly appreciated.
Smiling Ron
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Plasron
Re: Sheetcam
Post by Plasron »
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
robertspark
Re: Sheetcam
Post by robertspark »
:Like nice
Re: Sheetcam
Awesome, looks great! Glad you didn't give up. :Like :Like
Plasron
Re: Sheetcam - Open lines - Open paths
Post by Plasron »
Thanks guys, Now if I could wrap my mind around these 2 boxes, and fully understand them would be a load off my mind
Thank for the help
Ron
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
robertspark
djreiswig
Post by djreiswig »
The help button explains what the settings do.
Return to “SheetCam”
