Sheetcam - Open lines - Open paths
My brother and I have wasted so much metal TRYING to get an American Tattered Flag, I went in Inkscape and connected all the nodes, brought up Sheetcam and went through setting up operations, inside and outside.
The picture below is what I get, notice where the lines representing the stripes in the flag is mostly empty, a test run in Mac3 cuts it like Sheetcam shows it. What am I doing wrong?
Thanks in advance
Ron
Thanks in advance
Ron
Windows 10 64 bit laptop
Gorilla 4x4 table
Proma torch height control
Gecko mini gender changer to USB
Everlast 80 S Plasma cutter
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
- WyoGreen
Re: Sheetcam
The error code you are getting indicates you have some open lines, and some lines are either too close together or too small to machine. You need to be aware of your plasma kerf width when you design something. Looking at your picture, it appears there are a lot of bits and pieces of lines on your stripes.
There are a lot of tattered flags files on this site, some better than others. Do a search and take a look at a few and see how they handled the stripes.
Router
Laser
Router
Laser
Re: Sheetcam
Thank You WyoGreenWyoGreen wrote: Tue Jan 07, 2020 12:24 pm The error code you are getting indicates you have some open lines, and some lines are either too close together or too small to machine. You need to be aware of your plasma kerf width when you design something. Looking at your picture, it appears there are a lot of bits and pieces of lines on your stripes.
I wish I had never got involved with Plasma cutting, I don’t know how much more money my brother is willing to spend before he decides this stuff is way over our heads, I’m ready to give up on this waste of time and money hobby.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Re: Sheetcam
Most hobbies cost money. We all experienced the learning curve when we started. I still have a duh moment every so often.
Stick with it. It gets easier.
Re: Sheetcam
Where did you download the tattered flag from. I downloaded a regular flag from here. One thing is that I did differently is NO OFFSET and make it all one layer. Try it and see what happens. YMMV.
Re: Sheetcam
If you are cutting a line you use the no offset and they need to be cut all as one layer, They only have a start and end so if you use outside or inside they are closed start and end is the same place. To separate lines from the others use the contour function in Sheetcam to create a layer with all lines.
Re: Sheetcam
Thanks for the encouragement guys
I think I got one of the tattered flags here, I never thought of cutting on the lines, NO Offset, I will give that a try, do I do a lead in and lead out or no lead in and out.
Thanks again for the encouragement
Ron
Ron
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Re: Sheetcam
If it's just a line, you don't want leads.
Re: Sheetcam
Thanks djreiswig
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Re: Sheetcam
Good news, cutting on the line (no offset) worked great, some of the cuts didn't cuts left chads, but that was because of dirty files, If I go back and connect the lines and clean up the files there shouldn't be any problems with cutting.
Thanks so much for all you guys help, Greatly appreciated.
Smiling Ron
Smiling Ron
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Re: Sheetcam
- Attachments
- IMG_0326.jpg (51.05 KiB) Viewed 1232 times
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Re: Sheetcam
Re: Sheetcam
Awesome, looks great! Glad you didn't give up.
Re: Sheetcam - Open lines - Open paths
Thanks guys, Now if I could wrap my mind around these 2 boxes, and fully understand them would be a load off my mind
Ron
Thank for the helpRon
- Attachments
- job_options_001.png (18.7 KiB) Viewed 1202 times
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
Gorilla 4x4 table
Mach3
Inkscape
QCAD.
The help button explains what the settings do.
