Using fusion 360 strange extrusion
Ironys
Post by Ironys »
Hello,
I saw the Autodesk AutoCAD forum but didn't want to post there and break any rules.
While working on a fireplace log storage door I ran into this problem.
If anyone can point me in the direction as to why it's doing this I'd be greatly appreciative.
As you can see when i select the material i want to keep and extrude it sees it all just fine then i tell it to actually extrude it and it has these areas where its not cutting.
Thank in advance for any help.
Ironys
Re: Using fusion 360 strange extrusion
Post by Ironys »
Seems i step away from this software for just a day and I forget what I'm doing when i get back.
I figured it out. Turns out there was a discrepancy along the timeline in the lower left. It had two of the blocks greyed out. I selected the timeline and selected to delete everything past the marker.
It's done this before I just had a brain fart and forgot.
From 1:13 to 1:43 did not take you long, brain fart of not you feel better when you figure it out yourself, less likely to do it again.
Ironys
Post by Ironys »
lol true. Getting up there in years is not what I had planned.
I know the feeling any new things go into my right ear and old things fall out the left ear. :Sad
