PWM Sensor LEDs not working
Arclight Hardware discussion forum.
spuninmo
Post by spuninmo »
I realized today that my +5 light on the PWM sensor wasn't working. I thought this meant that my Cat-5 cord was maybe not working properly, so I replaced the cord. Lo and behold, the +5 light still didn't come on, even with power. I took the PWM sensor off of the machine, and pushed the button on the back that would activate the "test active" light, only to find that the light didn't activate.
I have power and air hooked up to the machine, so I don't believe that is the problem.
djreiswig
Re: PWM Sensor LEDs not working
Post by djreiswig »
Bad led? Can you measure the 5v with a meter to confirm if it is there or not?
Arclight Dynamics Tech
Post by Arclight Dynamics Tech »
Hey there!
Are you experiencing any cut issues? If so it could be something related to that light not being illuminated. That +5 light should be on but it is quite possible that it burnt out.
If you would like you can reach out to us via email at:
Support@arclightcnc.com
Or call at:
866-222-2154
Return to “Arclight Dynamics”
