looking for flat-pattern formula
I'm wondering if there is any formula for drawing boxes that are tapered,(there is a better name I'm sure,) for exmpe I am building a box with the top 12''x12'' and the bottom 8''x8'' with the depth being 3.5'', 3/16 material, I know in solidworks you can build your box and then flatten it to get the pattern, is there any other program that will do this?
- lockeyone
Re: looking for flat-pattern formula
Take a look here. Might get you close.
https://www.templatemaker.nl/
Table 4'x4', BladeRunner EtherCut 620 LINUX w/CommandCNC
Hypertherm 65 CPC/RS485 Machine torch 2016
BobCad router 50"x50" MACH3 2kw spindle 2003
Shoptask Eldorado cnc MACH3, 1999
Epilog Mini 24 60watt, 2013
Vectric Aspire CoralDraw x6 SheetCam
nice page
I've tried that and could'nt make anything work.
- lockeyone
I think it does. I typed in your dimensions into the Trapezoid style. Took PDF into my drawing program and removed the tabs. All shapes needed are there. If you have a break then you could cut less pieces for less welding. May have to adjust dimensions if you are trying to get outside or inside dimension right on.
At least I think this is what you are needing.
Worked like a charm. Thanks Lockeyone for the link!!!!!!!!!!!!!!!!!!!!!
I see, must not have used the right template formula, thanks a lot!
