Getting close to the finish
I am getting close to the finish of table #7, this is a scratch built DIY table. It is a 4X8 table base with both router and plasma torch mounts.
I have powered it up and did the steps calibrations home and limit switches are installed and wired. Attached are a few images.
- little blue choo
Re: Getting close to the finish
Looking Good
Rick
Rick
Rick
Arclight 9600 4x8 table
- Nacs Fab
Nice work as always. EDIT: sorry I see the carriages in the first pic. Again nice work!
G540 with LCTHC by candcnc
all built... by me...
First router cuts with my new table, Plasma will be next.
https://www.youtube.com/watch?v=X_i9ZzEp6PU
Always makes me think of terminator when I see a machine making parts for itself... lol
Looking good.
Looking good.
Very nice!!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
Testing dust shoe when routing wood and aluminum, video shows it in action (turn down the sound). Removed 100% of the wood and 99% of aluminum.
I used 2 different bits, "V" on wood and 1/8" ball nose on aluminum. Not pleased with the ball nose
I think the aluminum was sticking to it, will try a engraving bit soon.
https://www.youtube.com/watch?v=Rqg5sLQ4Y2w
Use flat end milling tool two flute up cut spiral for routing aluminum . Mist or flood coolant Ball end does not clear chip. V bit works on AL for simple signage.
thanks I will check into other bits
- little blue choo
Looking Awesome Tom!
Rick
Rick
Rick
Little more progress, attached a Drag Knife to the Z axis plate and cut some decals for the controller.
Also completed the Floating Head assembly.
Making some test cuts today with the router, I want to try custom Dovetails so I drew the 2 parts. Very happy with the first cuts I used a scrape to route them out and did a test fit. The orientation was not the way they would be for making joint but showed they will fit.
They ended up very tight need to adjust the finish allowance for a better fit.
