I have a new seat of design edge that is giving me fits on path conversion. Rounding corners on od paths and not cutting radius on id slots.
i_r_
anyone no what settings I need to change?Design Edge path conversion problems
Re: Design Edge path conversion problems
you might want to call Plasma Cam support.They've helped me a lot in the past.
Jim
Jim
I may have to. I made the same post on the users forum, with no replies.
i_r_
i_r_
Under setings--offset / convert, top right hand corner, where it says offest and there is a box around some options. Check chamfer outside corners, angle should be above 179 degrees, and check the box that says exclude crossovers.
See if that doesn't help.
Shane
Shane
