powder coat over galvanized
weld it
Post by weld it »
I have a customer who wants to know if anyone can tell him if there is a way to weld two galvanized steel parts together,then pretreat them,and powder coat them from rusting.
Don Bode
Corfabrication
Re: powder coat over galvanized
Post by Corfabrication »
galvanized sucks to weld, its not something you want to breath either.
you can powder coat over galvanized, I have had parts done in the past.
tnbndr
Post by tnbndr »
Best to grind off the galvanizing where you need to weld.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
I Lean
Post by I Lean »
Or if you can, build the parts first then have the whole thing galvanized after. (and then powdercoat if you need color or whatever...)
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
Welding galvanized is extremely toxic and causes a simptom referred to as metal fume fever. It can make you ill, vomiting and diahreah, blood pressure changes, pneumonia, chest pains, nausia, fever, chills, headache, acute lung injuries and causes cancer, can also cause loss of consciousness within a matter of minutes in extreme conditions. Only weld it if you are very familiar with doing so and have all the proper ventilation, gas masks and safety equipment.
Torchmate CAD
vatso
Post by vatso »
I made a water tray for my plasma table and tid welded the edges which were galvanized it was only 4 small welds and it's been okay for more then a year.
like the other said it's not safe to weld
conradestrada
Post by conradestrada »
I won't weld it but we do blast and powder it mostly for the appearance of zinc is what it kind of looks like with a 20% gloss but I damn sure won't weld it if you do drink a lot of milk do it in a well ventilated area and wear a cartridge mask.
Return to “Powder Coat”
