I have a customer who wants to know if anyone can tell him if there is a way to weld two galvanized steel parts together,then pretreat them,and powder coat them from rusting.
Don Bode
powder coat over galvanized
Re: powder coat over galvanized
galvanized sucks to weld, its not something you want to breath either.
you can powder coat over galvanized, I have had parts done in the past.
- tnbndr
Best to grind off the galvanizing where you need to weld.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Or if you can, build the parts first then have the whole thing galvanized after. (and then powdercoat if you need color or whatever...)
- Gamelord
- 4.5 Star Member
Welding galvanized is extremely toxic and causes a simptom referred to as metal fume fever. It can make you ill, vomiting and diahreah, blood pressure changes, pneumonia, chest pains, nausia, fever, chills, headache, acute lung injuries and causes cancer, can also cause loss of consciousness within a matter of minutes in extreme conditions. Only weld it if you are very familiar with doing so and have all the proper ventilation, gas masks and safety equipment.
I made a water tray for my plasma table and tid welded the edges which were galvanized it was only 4 small welds and it's been okay for more then a year.
like the other said it's not safe to weld
I won't weld it but we do blast and powder it mostly for the appearance of zinc is what it kind of looks like with a 20% gloss but I damn sure won't weld it if you do drink a lot of milk do it in a well ventilated area and wear a cartridge mask.
