Fine cut consumables question for Mr.Colt.
B Holmes
Post by B Holmes »
Jim. I was just thinking how nice it would be to have shielded fine cut parts. Any possibility of that in the future?
5 x 10 Air bladder water table
Precision plasma HDB gantry
CandCnC 620-4 Bladerunner
Feather touch ohmic plate sensing
Hypertherm Powermax 65
2015 Autocad lt
Mach 3
Central California
Re: Fine cut consumables question for Mr.Colt.
Post by jimcolt »
One of the important features of the Finecut nozzle design is the ability to keep cut edges as close to square as possible. To do this you need high energy density and low arc voltage. To get low arc voltage the nozzle orifice needs to be very close to the material......adding a shield forces the nozzle orifice to be further away from the material, increasing arc voltage.
While I am not ruling it out, currently there is not technology that allows the same quality as Finecut consumables in a shielded version. I doubt that we will see any shielded Finecut technology in the near future.
Jim Colt
B Holmes
Post by B Holmes »
Thank you for the explanation.
2015 Autocad lt
Mach 3
Central California
_Ogre
Post by _Ogre »
i use the finecut ohmic shield any time we have finecut consumables on the table
it is barely a shield but will save the finecut tip from rubbing or crashing into the material
we do a lot of non traditional cutting on our cnc table, mostly on 2.5'' ss tube held in a fixture
Post by jimcolt »
That is the correct "shield" to use with the finecut parts as it extends slightly below the nozzle.....protecting it from dounle arcing to the plate. Officially though......shield technology covers the nozzle completely...as it does with the higher powered consumables on Hypertherm systems.
Jim Colt
jbc28
Post by jbc28 »
I've been using the non shielded deflector (part # 220955) with finecut. Can I use this ohmic shield (part # 220948) even if I don't have ohmic sensing on my table?
LDR 5x10
Me to book shows the 220948 mounting with the retaining cap for the ohmic sensing.
urbnsr
Post by urbnsr »
I use 220948 without ohmic sensing. I feel like I have more protection using it.
This is the chart I go off of:
Paul
Post by jimcolt »
In my opinion (which is sometimes different than our product managers) the only part to use with the Finecut consumables is the 220948 shield....for hand and machine cutting, with or without ohmic contact.
Reasons:
- extends slightly below the nozzle
-Eliminates arcing between nozzle and plate
-Improves nozzle life
-If you have ohmic contact...you must use this one.
-Cools the nozzle better
-If height control drives torch in the plate...generally no damage occurs.
jbc28 wrote:I've been using the non shielded deflector (part # 220955) with finecut. Can I use this ohmic shield (part # 220948) even if I don't have ohmic sensing on my table?
new parts on the way thanks for the info :)
_Ogre
Post by _Ogre »
jimcolt wrote: -Improves nozzle life
my main reasons highlighted :mrgreen:
i use the 948 anytime we have finecut on the table
