Help on pricing.
KeeYaw
Help on pricing.
Post by KeeYaw »
Friend of mine has a friend who owns a Fab Shop and ask me to do some work for him. Have to cut 16 to 24 of these. He is supplying the material, all I"m doing is cutting. They are 4" x 9" x 3/4. Just curious what others would charge for cutting something like this.
m79b01
Re: Help on pricing.
Post by m79b01 »
I only have a 65 so I don't do 3/4" but I would say around $8 each. I will be interested to see other input.
Precision Plama LLC SDB 5x10
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
https://www.facebook.com/burtonskustom
tirediron
Post by tirediron »
Do a search on spreadsheet and you will find a very helpful way to charge your customers, especially those that you are doing multiple parts.
KeeYaw
Post by KeeYaw »
I did look at the spreadsheet but it only goes up to 1/2. Plus, the prices on the spread sheet is what shops using water jet are charging. Plasma is half that price on spreadsheet.
tnbndr
Post by tnbndr »
The spreadsheet is a basis with which to start. You have to modify for prices in your area, for steel, consumables, etc.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
What about the holes. 3/4" thick steel with 3/4" diameter holes. Are they going to be plasma cut too or would you have to drill them to get good enough quality.
Something to consider in the pricing.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
KeeYaw
Post by KeeYaw »
beefy wrote:What about the holes. 3/4" thick steel with 3/4" diameter holes. Are they going to be plasma cut too or would you have to drill them to get good enough quality.
Keith.
Just cutting no drilling.
Coffinscreekcustoms
Post by Coffinscreekcustoms »
$8 sounds fare to me!!!!!!
mdwalker
Post by mdwalker »
I generally only cut up to 5/8" material but If I were to cut them they would be $25.12 each if I furnished material or $23.87 for 20+. If they furnished material they would be $18.75 each or $17.50 for 20+. This price is based on 5/8" material.
Danny Walker
Walker Manufacturing
Tishomingo, Oklahoma USA
www.walkermfg.net
Shane Warnick
Post by Shane Warnick »
If all I had to do was the cutting, and I furnished the material, I would be around $17 each for the quantity you listed above. If I was going to be doing a higher volume then it would be less per each depending on the quantity. That is assuming, as you said, all cutting no drilling. I would cut them and then throw them into the tumbler so secondary process would be a minimum. If the customer insisted on acid dipped or hand grinding each one with a flap disc, then add another $2-3 each depending on the quality required.
Shane
beefy
4.5 Star Member
4.5 Star Member
Post by beefy »
You said the customer is a friend of your friend. Has the customer seen a sample of one of your plasma cut holes ? Would they be satisfied with the "quality" of the finished hole. I think some customers think plasmas can cut holes like a laser.
Some seem to have better luck than others with plasma cut holes but I think with 3/4 diameter in 3/4 thickness, everything will have to be spot on to get decent holes.
Just a thought,
Keith.
LinuxCNC
Coreldraw 2019
KeeYaw
Post by KeeYaw »
beefy wrote:You said the customer is a friend of your friend. Has the customer seen a sample of one of your plasma cut holes ? Would they be satisfied with the "quality" of the finished hole. I think some customers think plasmas can cut holes like a laser.
Just a thought,
Keith.
They will drill out the holes.
KeeYaw
Post by KeeYaw »
Thank you all for input! I purchased this table at the begining of year for personal use to fab projects for home, shop, and property we are building on. Word got around that I have a table and now ppl are coming to see if I would do work for them. My first gut feeling was around $20 a piece but really had no clue. Thank a bunch again!
vmax549
Post by vmax549 »
That would be about 70 sec of cutting. So at $100 per hour for cut time. That would be $2.10 each PLUS $2.10 cleanup and handling @ $100 per hr ShopTIme. PLUS Art time @ $35 per hour
$4.20 each in volume Plus Art Time.
(;-) TP
tnbndr
Post by tnbndr »
I would hire vmax549 to cut them for you, even with shipping you could come out ahead.
Now that you are cutting them, did you ask enough money??
What did you quote them and how did the cutting go?
grindergary
Post by grindergary »
vmax549 wrote:That would be about 70 sec of cutting. So at $100 per hour for cut time. That would be $2.10 each PLUS $2.10 cleanup and handling @ $100 per hr ShopTIme. PLUS Art time @ $35 per hour
(;-) TP
Terry,
If this is how you do your calculations, Where is your costing for material?
Just trying to get my head around what you are doing.
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
rikduk
Post by rikduk »
I would charge 7$ each to cut 20
+18$ drawing/handling (its a simple piece)
+material
no cleanup
