Cleaning dross with air chisel
f_armer
Post by f_armer »
I have tried all methods of dross removal, and I thought I'd share what I've found to works best.
For most things, an air chisel. put in a flat chisel, turn the air pressure right down so it is just hammering slow, and get at it! The vibration seems to make the dross fly. Sometime you gotta hit it at different angles, put it is by far the easiest way of chipping slag.
If I have small very detailed items, I usually put them in muratic acid, but the air chisel is very controllable on fine detail and works very well for detailed stuff too.
I haven't seen this method suggested before, so I thought I'd share.
I just use a cheap one because you don't need lots of hammering power.
This type of air hammer if anyone is wondering.
http://www.amazon.com/Wilmar-M668-Heavy ... rid_pt_1_1
4x8 bulltear
Hypertherm pm45
Miller 252
Miller syncrowave 210
CNCCAJUN
Re: Cleaning dross with air chisel
Post by CNCCAJUN »
I have tried an air chisel. I got good results like you except on detailed items.
Suggestion on the air chisel. TANTO grind the the chisel. Meaning one angle like the blade on a plane.
Grabs the dross better and allows you to operate at a lower angle which will be less likely to glide over the dross.
Steve :D
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Brand X
Post by Brand X »
I have been using them for a while.. Kind of prefer this brand for most of my air tools.. You pay a price for smooth, and quiet. Air file is awesome too..Ebay can take a lot of the sting out of the price.. :lol: Air grinders are beyond smooth..
http://www.nittokohki.com/tools/product ... index.html
DXF
Post by DXF »
I have been using an air chisel from the Chinese place for years. Works great! Been looking for a round one like in the link Brand X posted. Thanks for the info. I think it would be easier to use than the pistol shaped handle.
Dave Hanks
Gearheadmex
Post by Gearheadmex »
Harbor Freight, has an inline regulator and a one sided taper so you can lay flat and not drive into the metal or details.
EZ Router APC 4 x 8
V- Carve Pro
SheetCam
Mach3
Brew Worx
Post by Brew Worx »
Picked up one from Harbor last night. 20% coupon of course. Works great.
Brew Worx.
Blue Frog Metal Works
Chicagoland
Arclight 4800 :D :D
Hypertherm 45
4 inch tube cutter
Mach 3, SheetCAM, Solid Edge 2D, Solid Works 3D, CREO, Inkscape, and a few cobb webs
