Refrigerated Air Dryer from Harbor Freight
I got a refrigerated dryer from Horrible Freight (Harbor Freight) and have been very pleased with it. I have an in line Motor Guard filter but I don't really think it was needed. I do have an automatic unloader on my air compressor that drains moisture from the bottom of the tank each time the compressor kicks on and this helps keep the air drier.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
Re: Refrigerated Air Dryer from Harbor Freight
I've had a HF $300 refridgerated air dryer for about 5 years and can say that I've had zero issues with it. It is identical to a $1800 dryer that a local welding company sells in their store under another name.
- Complete_Loser
Thanks guys. Just want i been researching.
You want it done cheap and fast, it wont be right.
You want it done right and fast, it wont be cheap.
You want it done right and cheap.., come back in a year..
Will vouch for the Harbor Freight dryer.....shop at the right times and you can get it for $199 like I did.....mines been functioning great for 3 years now.....hope I didnt just jinx myself.....
:::Paul Wilson:::
Stay Gold!
Stay Gold!
I'm looking at one of these as well maybe if someone notices it's on sale they could let everyone know.
G
G
I have had my HF dryer for about 5 months now with zero issues and consumables last about 25% longer.....Russ K.
- elkriverfab
I have heard they work pretty good.
I thought about getting one myself for a while.
I used my home made dryer the last few days under some heavy cutting time and it did a great job.
I checked it on a regular basis just to make sure it was doing what it was made for and I am very happy with it.
I just keep some water bottles and soda cans in it to help keep the box cold (and to keep from getting thirsty).
It has been really humid here the last few weeks and it has pulled a lot of water out of the air.
I am sure yours works better if you were to rate the two under heavy production, I am not sure.
I was given a dorm size refer and thought it would use it for air drying also.
I am happy your unit is working for you. Tools and equipment are so expensive and I have found that working for yourself means stretching every dollar to keep in production.
I too have found my consumables to be lasting longer. Those things can be costly and I have also found the cuts to be better with the dryer air.
It pays in the long run to either buy an air dryer or build one.
If you're not opposed to buying used it can pay off to watch Craigslist or ebay. I was just getting ready to get the Harbor Freight unit when I found a 100 CFM Ingersoll Rand on ebay that was close to me and got it for $76 in great shape. It's about 5 times as big as what I need right now but I plan to set up a big sandblaster soon so it will be good to have the extra size.
Just thought I'd chime in. I ordered one of the HF refrigerated dryers on new years day with a coupon that let me grab it for $300. (reg price is now $400)
I got it yesterday and it works fantastically, out of the box! I'll post back here periodically for updates about how it is holding up.
Well, after several years my dryer is still running strong. Haven't had the need to recharge once, and am still getting dry air.
- little blue choo
When I went to Arclight for training on my table they were using a HF dryer on their table and recommended it highly. I've been using mine for just over a year and it works great. Can't beat it for the money.
Rick
Rick
Rick
Arclight 9600 4x8 table
- Nacs Fab
I am also on the bandwagon for the HF Dryer. Mine has been running for 2 years now and no problems.
G540 with LCTHC by candcnc
all built... by me...
- rons
On my third one but that was from shipping damage, But what I did to make it virtually silent was remove the compressor bolts and stop the transmit of noise I also used double sided stick foam at all the sheet metal seams, works great.
Question do you leave yours plugged in and on all the time?
Ron
Ron
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
Those if you with the HF air dryer are you running a pre-oiler on the input to the dryer?
You don't want to contaminate your refrigerated dryer with oil.nm5c wrote: Thu May 22, 2025 12:59 am Those if you with the HF air dryer are you running a pre-oiler on the input to the dryer?
You do not want to have an inline oil system on any air supply going to your plasma cutter! It will contaminate everything from the plasma power supply to the tip of the torch and cause lots of problems.
What weldguy said. I assumed you were asking about a setup for general shop tools (air tools, etc.) and not for plasma cutting. For shop tools, but your oiler (if you must have one) right before the air tool. No oil for plasma cutting, blast cabinets, etc.
