Modified Tube Roller
Oldsarge
Post by Oldsarge »
This is a tube roller I cut this past weekend... I forget who posted the original file, but I got it here.... I saw a similar version that SWAG offroad just started marketing, so I integrated some of what I saw there. This version allows you to change the distance of the bottom rollers without pulling pins and wrestling with rollers and such, they just drop in! Also incorporated the bottle jack feature, and this coming weekend I'll be adding some bits and pieces for the pipe threader attachment.... Will do a bit of powdercoating when it's finished.... Cut from 1/4" pretty heavy! I'll post some pics after it's finished and I have a chance to test it out...
Oldsarge
6x12 Home Built Table
Hypertherm PowerMax 85
762frmafr
Re: Modified Tube Roller
Post by 762frmafr »
Is this the one Tnbndr posted?
Oldsarge
Post by Oldsarge »
Got most of the fab work finished on the roller today. Tomorrow I just need to do a little finish welding and drill and tap the mounting holes for the manual crank. Then it's just a matter of disassembly for powdercoating and final assembly. I have a few tweeks to do on the DXF file, but it's pretty close... If anybody's interested let me know and I'll post the file(s)
Oldsarge
Oldsarge
Post by Oldsarge »
762frmafr wrote:Is this the one Tnbndr posted?
YES! Thanks for reminding me... Thanks to Tnbndr for the original file!
Oldsarge
Post by tnbndr »
Thanks for the photo montage. I still have to finish mine. I like the spring location change.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
I Lean
Post by I Lean »
Oldsarge wrote:. I have a few tweeks to do on the DXF file, but it's pretty close... If anybody's interested let me know and I'll post the file(s)
Oldsarge
I'm interested! Thanks in advance. :D
GoingCustom
Post by GoingCustom »
Same here! Thank you :)
Travis
one of a kind gates, fine art and CNC designs
762frmafr
Post by 762frmafr »
I am also interested in the DXF File. One of the questions I had for Tnbndr that was not answered in his post was this: With this DXF File, do you still have to buy the Harbor Freight roller to use some parts off of it? Or is this a complete roller? Thank you in advance. Steve
Oldsarge
Post by Oldsarge »
For right now the only parts that are from the original roller is the yolk for the drive roller. To fab that up you would need a 42mm drill bit, or some way to cut our machine an accurate 42mm hole for the bearing. I found one for $135 which is actually pretty good for a bit that size.... Also the drive shaft, and the shafts for the bottom rollers are original, but if you plan to do any kind of rolling on a regular basis, I'd order a set of hardened replacement shafts from Swag, or make your own from hardened rod if you're able to machine the flats for the set screws.... I also located a source for a digital readout so that you will have very accurate repeatability if you need to make multiple parts.... Just take the tension up on the tube, zero the display and Roll to your desired radius, and just keep track of what notches the bottom rollers are in and the reading from the dro and you can go back any time and repeat that part!
Oldsarge
762frmafr
Post by 762frmafr »
Oldsarge wrote:For right now the only parts that are from the original roller is the yolk for the drive roller. To fab that up you would need a 42mm drill bit, or some way to cut our machine an accurate 42mm hole for the bearing. I found one for $135 which is actually pretty good for a bit that size.... Also the drive shaft, and the shafts for the bottom rollers are original, but if you plan to do any kind of rolling on a regular basis, I'd order a set of hardened replacement shafts from Swag, or make your own from hardened rod if you're able to machine the flats for the set screws.... I also located a source for a digital readout so that you will have very accurate repeatability if you need to make multiple parts.... Just take the tension up on the tube, zero the display and Roll to your desired radius, and just keep track of what notches the bottom rollers are in and the reading from the dro and you can go back any time and repeat that part!
Oldsarge
I have a buddy with a mill that I am sure would be able to hook me up. Whenever you have time, or are ready, I would greatly appreciate the DXF files. Also, some measurements on the yolk or maybe a simple line drawing would also be greatly appreciated. Thank you very much. Steve
Post by tnbndr »
Sorry, I must not have seen that post. If you use this dxf file you do not need any parts from the Harbor freight unless you want the dies. I would save the money and buy the dies from Swag Tools. You can get the shaft and bearings also.
http://www.swagoffroad.com/Metal-Fabric ... -_c_7.html
In the upper right hand side is a link to his dies and parts.
Here is another helpful thread:
http://www.offroadfabnet.com/forums/sho ... php?t=9696
Coffinscreekcustoms
Post by Coffinscreekcustoms »
I would love the DXF I was thinking of buying one but then I said I would make one!!! But didn't know where to get the rollers !! Looks great thanks Jake
Post by tnbndr »
Here is the original dxf file that I posted. You can modify to get to what Oldsarge posted if he does not want to post his dxf file.
Tubing Roller.dxf
Oldsarge
Post by Oldsarge »
abmagrum
Post by abmagrum »
THANKS !!!
TNBNDER , OLDSARGE
Greatly appreciated
Al
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
762frmafr
Post by 762frmafr »
Tnbndr, I have finally gotten to the point that I am ready to build my tubing roller. I opened your DXF as well as Old Sarges. I do not see the bearing carrier dimensions in either file. Also, I cannot seem to find your original post on here. If you could link me to it, I would appreciate it.
Post by tnbndr »
I did not build the bearing carrier, I used the one from the Harbor Freight roller that I bought. It is all a moot point now as I sold all my pieces to a member here and he has completed the project. I found an Eagle Roller used that I ended up purchasing.
I cannot find my original post either but it only had the dxf file and a picture.
Oldsarge
Post by Oldsarge »
I don't think I included the dxf for the upper assembly in my previous post. I cut mine from 1/2" the bearing is I believe 42mm or 1 21/32 which is just a hair over 42mm. I ordered bearings from vbx which are a direct replacement, it was like $20 plus shipping for 10 of them. The hardest part of this build is getting those dang 42mm holes drilled. If you have the right setup it's easy. The next 2 I build I'll be sending to a friend who has a CNC mill to do that part of it.
I'll post the rest of the files when I get a chance to get over to the shop...
I posted that this was going to be one of my last projects, but I'm currently working on a clone/version of a Kmg 2x72 belt grinder.... I have a 2 hp 2 phase motor and a vfd as well. This is going to be an amazing grinder, and I'm trying to get it finished before Christmas.... I'll be turning all the drive, tracking and idler wheels myself. S configured on line this grinder would cost a bit over $3k I figure I'll have about 600 in it. If I can sell a few I might keep things afloat a while.... I'll post pics when I get to that point...
Hope everyone has a great Christmas!
Oldsarge
Self-MadeFabWerx
Post by Self-MadeFabWerx »
i would definitely be interested in file. im looking at getting a roller and I would rather build one then buy one for $700+
here is one I downloaded some time back, similar to the one here I have not cut it and you may need to mod it for your use.
ROLL BENDER FRAME side.DXF
PineyWoodsFabrication
Post by PineyWoodsFabrication »
THanks for sharing these files
mikeg53549
Tube Roller
Post by mikeg53549 »
I have a friend offering a wheel tube roller for near free. Is this something useful in plasma projects? examples?
Once you have a tool you will find a use for it. It depends on the type of projects you have waiting to build.
Red6rubicon
Post by Red6rubicon »
You can do alot with a tube roller
Paul9207
Post by Paul9207 »
I know this is an old thread, but does anyone have the updated dxf for this roller? Been wanting to make one for a while.
