Differnt color lines in Sheetcam what do they mean?
t8017e
Post by t8017e »
Now I got my full version of sheetcam when I import drawings to make posts, I get some red lines, some yellow lines and some blue lines. I need to know what they mean and how to get them all the same I believe red is the default. It seams the posts come out correct when everything is red.
Any Info?
I Lean
Re: Differnt color lines in Sheetcam what do they mean?
Post by I Lean »
Red is an exterior contour, yellow is an interior (like an inside hole), blue is a rapid movement. (not a cut) White is an open line, as opposed to a "closed" shape. (like a single straight line, or something with lines that aren't joined)
t8017e
Post by t8017e »
How do you assign what you want. I imported a drawing and one of the cuts is an inside yellow and all the others are red. When I set a cut operation, the green trace lines are one inside and one ouot side. I want them all the same red. So my question is how can you change them in sheetcam.
kbenz
Post by kbenz »
check this site out. has some good tutorials on sheetcam http://arclightcnc.com/training.html
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
I Lean
Post by I Lean »
You can select whether the cut is inside or outside offset in the operation--but that will change ALL of them in the drawing--so if all but one are correct in one drawing, you might need to change that one contour to a different layer. That way it can have it's own operation, separate from the rest of the drawing. (Select Edit contours, then right-click over the desired area -> Move to Layer -> New Layer, type a name for your new layer, then assign a cutting operation to that layer)
t8017e
Post by t8017e »
The first attachment I have this problem with the top of the R. The second drawing I have the problem with the center cut outs 4 are yellow and one is white.
BR12T 1.5R TUBE MOUNT BAG PLATE.DXF
(32.36 KiB) Downloaded 117 times
WARNING THIS IS GARDENA.dxf
(125.17 KiB) Downloaded 101 times
t8017e
Post by t8017e »
I figured it out on the warning sign. There was a small little line attached that wasn't needed.
This file should cut good now.
(124.96 KiB) Downloaded 110 times
Return to “SheetCam”
