Gorilla Machines
Re: Gorilla Machines
Post by djreiswig »
Glad to hear you got it going.
tdarn1
Post by tdarn1 »
I have a used gorilla machine for sale if anyone needs any parts , no software, needs a gecko drive , everything else is in good shape , bought a new 8ft table.
Tdarn1@gmail.com
nobrainer357
Post by nobrainer357 »
I have a spare gecko drive if you want to buy it. Im currently trying to get my gorilla machines table working and bought it and found it want the problem.
nobrainer357
I've had the gorilla machines table for 3 years, and out of now where the table stopped working. In the diag screen, it shows all of the limits being triggered and the ports show no green boxes. I've already replaced the gecko 540 and the uc100. Can anyone please give me some advice... beside burning this thing to the ground.
bc56845
Post by bc56845 »
A friend of mine sent me a screen shot from facebook this morning(I dont have facebook) about someone with this exact problem on a Gorilla table and the problem was the kernel speed being set wrong. Whoever posted said the Kernel speed needed to be 35K hz. But, my gorilla table is set at 45K Hz and its working. Was that you?
Post by tcaudle »
There are tiny elves that sneak around at night and fix things but beware because there are bad elves that will break things . Sometimes leaving it set will alert the good elves and its working again. Once the bad elves let the blue smoke out of the electronics the good elves can't make it work :Yay
Post by djreiswig »
Somebody told me that when they make each one of those electronic parts they put a little bit of smoke inside to make them function. Once the smoke gets out they don't work anymore, and it's impossible to put it back inside.
Dooggins1
Post by Dooggins1 »
Anybody out there have the correct parameter for these damn machines. I tried the one in here and still can get the other y motor to move at all. It worked great and ai deleted the computer I had it on because I was selling it. Went to reload everything now it can’t find the driver. Any help is appreciated. It was working great until I did that.
Dooggins1 wrote: Fri Jun 06, 2025 7:30 pm Anybody out there have the correct parameter for these damn machines. I tried the one in here and still can get the other y motor to move at all. It worked great and ai deleted the computer I had it on because I was selling it. Went to reload everything now it can’t find the driver. Any help is appreciated. It was working great until I did that.
Good luck!
Dooggins1
Post by Dooggins1 »
well i got it moving correctly but cant get any of my limit/ home switches to work
Dooggins1
Post by Dooggins1 »
Update again....got my limit switches going but when i ref all home the switch on the probe does not work when it goes down to touch material. it would just keep trying to lower if i let it.
Post by tcaudle »
Touch off is not a reference move. Typically the Z swith is setup as a Probe function and tha is ignored on a Home move.
IF the Z switch is setup as a Z home it should stop just like the others . If its not, take that call out of the Homing macro.
Watt an input does (its Function) when its tripped is determined by the function Name in the Posts and Pins .Input Signals
