LDR Motion Systems Tube Cutting Machine Issues
We've got an LDR tube cutting machine at work here where I'm the main operator. My computer recently had an update, to which it put the CAM software (Fabrimaster) back into demo mode by referencing the wrong license key I assume. Has anyone else ran into this?
Outside of this issue there has been numerous small issues that hindered flexibility and efficiency that I have found solutions to if anyone else running this machine has had any problems I would love to hear them and what the solution was.
We have the 6" x 6" x 24' machine with scribe and water functionality.
Re: LDR Motion Systems Tube Cutting Machine Issues
Have you contacted LDR tech support?Braxton_Bargmann wrote: Mon Feb 03, 2025 5:06 pm We've got an LDR tube cutting machine at work here where I'm the main operator. My computer recently had an update, to which it put the CAM software (Fabrimaster) back into demo mode by referencing the wrong license key I assume.
David -
LDR Motion Systems unfortunately burnt down a couple years ago now along with all of the files, documentation, hardware, and notes.
Braxton_Bargmann wrote: Mon Feb 03, 2025 6:33 pm David -
Can you contact the software manufacturer directly?
I am sure contacting Fabrimaster can get your software back up and operational. As for the equipment there are some others here with that setup who hopefully will chime in.
I have tried to find any contact information available for TCS Fabrimaster with no luck as I can't get access to their website due to security issues.weldguy wrote: Tue Feb 04, 2025 10:08 am I am sure contacting Fabrimaster can get your software back up and operational. As for the equipment there are some others here with that setup who hopefully will chime in.
Does anyone on here have a contact for TCS by chance?
Thanks so much!adbuch wrote: Wed Feb 05, 2025 1:16 am I had no problem accessing their website.
https://www.globaltcs.com/ContactDetails.htm
Happy to help! Let us know how you make out.Braxton_Bargmann wrote: Wed Feb 05, 2025 7:22 amThanks so much!adbuch wrote: Wed Feb 05, 2025 1:16 am I had no problem accessing their website.
Got ahold of the head software engineer and worked through all of my issues. Thanks!adbuch wrote: Wed Feb 05, 2025 8:00 amHappy to help! Let us know how you make out.Braxton_Bargmann wrote: Wed Feb 05, 2025 7:22 amThanks so much!adbuch wrote: Wed Feb 05, 2025 1:16 am I had no problem accessing their website.
Awesome! Are you able to give a quick summary of what fixed it in case someone else has a similar issue in the future?
It was the software referencing the wrong license within the code in my computer.weldguy wrote: Wed Feb 05, 2025 3:56 pm Awesome! Are you able to give a quick summary of what fixed it in case someone else has a similar issue in the future?
That's great, thanks for posting your solution
