Pencil Adapter for a Sharpie holder STL
Topics related to pen markers, remote controls, drawing tablets, & other plasma table related accessories
jmersereau
Post by jmersereau »
I found an adapter at https://www.thingiverse.com/thing:5422309 that allows for the use of a short 7mm pencil (like you get at the golf course or from catalogue stores to fill out forms) in place of a Sharpie pen and it works great. Also, 8mm hex and round pencil adapters.
The tolerances are very close so I had to spend a quick minute with a fine file both inside and outside of the adapter to get it to slide perfectly.
Vert_CNC_pen_holder_7mm_pencil_insert-Part.stl
Vert_CNC_pen_holder_8mm_pencil_insert-Part.stl
Vert_CNC_pen_holder_8mmround_pencil_insert-Part.stl
PrimeWeld CUT60
Langmuir CrossFire Pro
05Duramax
Re: Pencil Adapter for a Sharpie holder STL
Post by 05Duramax »
Cool, thanks. Another tool that would be great. Hopefully my buddy can print one of these for me as well.
I assume that this will not be using the spring, but is a snug fit for the adapter.??
jmersereau
acourtjester wrote: Sun Jan 05, 2025 11:24 am I assume that this will not be using the spring, but is a snug fit for the adapter.??
You are right it does not use the spring in the holder. Yes, it is a snug fit.
I showed it in "my" CNC Sharpie adapter as a test fit. I was providing for the other designs that use Sharpies with floating mounts.
PrimeWeld CUT60
Understand thanks
Return to “Pen Markers, Remote Controls, Drawing Tablets, etc.”
