6'' Velox z axis side plates
- SeanP
I made these up as I was noticing a bit of flex in the back plate of the z axis, adding these cured that all together.
You might notice I have fitted a extra linear bearing on the lower part, I was just starting to feel a little play in the original so squeezed another bearing on either side, it's been like that for 12 months now, just oil and clean fairly often.
It was just a cheapo chinese bearing I had, don't think it's any different quality to what velux supplied.
Link here to diy breakaway mount fitted also
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
- Capstone
Re: 6'' Velox z axis side plates
Thanks Sean
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Digging up an old post...
Does anyone have any more info on the plastic bearings used in the Velox Z axis slides?
Mine are finally worn out and wobbly, and the Velox website says they are permanently closed down.
Before I take it apart to start measuring I wanted to get an idea of how readily available they are so I can plan for it.
- SeanP
I see plenty of those listed on eBay, I fit some cheap Chinese ones a while back and still fine, keep plenty oil on those.
It's the lead screw I'm hunting for at the moment and that delrin nut, I must get something soon it's badly worn in the middle
Powermax XP45
Table build gallery
Table build gallery
Sean I made many of those Delrin nuts for the tables I build, very easy I used an Acme threaded rod for the lead screw. I can give you the info if you want.
- SeanP
Thanks that's very good of you Tom, but I'd be struggling to get them made up I'd say, I don't want to deviate too far from what's fitted now really, but it ain't easy sourcing the same nut, it's the anti backlash one with a spring, I'll do some more searching.
Powermax XP45
Table build gallery
Table build gallery
You may look into the 3-D printer world I have seen anti backlash nuts for sale they are for a 8 mm lead screw. Not sure what size you need.
Tom - you show an excellent alternative to purchasing "store-bought" parts.acourtjester wrote: Mon Dec 16, 2024 5:16 pm Sean I made many of those Delrin nuts for the tables I build, very easy I used an Acme threaded rod for the lead screw. I can give you the info if you want.
SeanP - I would just measure up the ones you have now and find matching replacements. If you would care to share the specs/dimensions for your lead screw and nut - I will be more than happy to help you find suitable replacements.SeanP wrote: Mon Dec 16, 2024 6:11 pm Thanks that's very good of you Tom, but I'd be struggling to get them made up I'd say, I don't want to deviate too far from what's fitted now really, but it ain't easy sourcing the same nut, it's the anti backlash one with a spring, I'll do some more searching.
Thanks David, big believer in DIY
"Tom - you show an excellent alternative to purchasing "store-bought" parts."
- SeanP
Managed to squeeze in a couple of hours to get the info today, prepare to be shocked when you look at the leadscrew condition I know I was!adbuch wrote: Mon Dec 16, 2024 11:57 pmSeanP - I would just measure up the ones you have now and find matching replacements. If you would care to share the specs/dimensions for your lead screw and nut - I will be more than happy to help you find suitable replacements.SeanP wrote: Mon Dec 16, 2024 6:11 pm Thanks that's very good of you Tom, but I'd be struggling to get them made up I'd say, I don't want to deviate too far from what's fitted now really, but it ain't easy sourcing the same nut, it's the anti backlash one with a spring, I'll do some more searching.
It's even more urgent than I thought, I'm going to try again now to find the same part, it would be great if you do see a replacement.
Pics and details here:
https://photos.app.goo.gl/XTpYDojFmCtm7wpJA
Powermax XP45
Table build gallery
Table build gallery
- SeanP
Yes min is a 12mm tread, I do keep seeing a lot of the smaller screws and nuts for 3d printers, better get looking again, it's only just holding on to the last threads, you wouldn't believe how much cutting it's done!acourtjester wrote: Mon Dec 16, 2024 7:38 pm You may look into the 3-D printer world I have seen anti backlash nuts for sale they are for a 8 mm lead screw. Not sure what size you need.
Powermax XP45
Table build gallery
Table build gallery
Man you have been working the table to hard, It need a few days off in the South France.
You may need to rework the entire Z drive assembly
Here is something that may help they sell different lengths of lead screws and ship to EU and BR
https://www.aliexpress.us/item/32568051 ... pt=glo2usa
This one you would need to machine the ends to fit you setup. China no prices??
https://www.njskt.com/custom-made-12mm- ... crews.html
- SeanP
Yes looking like I won't find the same nut, spent last 2hrs searching the world
I'd probably get away with a circular one with a bit of modifying, be lucky to get the same longevity from another one though, wonder how brass would fair?
Powermax XP45
Table build gallery
Table build gallery
Buy a few spares and use a dry lube, when your down any fix will do to buy you some time.
- SeanP
Just a update on the leadscrew,
I eventually found near enough the right screw, went for a 12x6 - 2 start and got a pal to turn the ends.
Just by chance I found a discussion about making a delrin nut, so thought I'd give it a try, ordered a length from alliexpress and it worked a treat.
I don't have a lathe so mounted it up in the pillar drill, rigged up a rest and did some old fashioned wood turning with a chisel, head cocked over at 90deg mind!
Been cutting away now for a few weeks, runs better than ever.
https://www.denfordata.com/bb/viewtopic.php?t=3727
I had the 2 halves packed up to the centre of the vise jaws, heated the screw till it was about straw colour with propane, squeezed it up, then I cooled it in water.
It didn't take much working to get a very nice fit, welded together no problem, I did grind a small flat on the screw like it shows in that post.
So I have enough material to make another 10!
Powermax XP45
Table build gallery
Table build gallery
Good show they worked for me on the tables I built and for supplying them to other for their table.
