PDF scan or image to dxf
smilintodd
Post by smilintodd »
Hi I'm wondering if anyone can trace this pdf image for me. I can scale it to the size needed, but the overall length is about 10 inches if it were horizontal.
Joe Jones
Re: PDF scan or image to dxf
Post by Joe Jones »
Didn't we do this one already?
You can find the signature in a black and white image on Google IMAGES. That would be a LOT easier to trace or copy than using this photo.
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
An Inkscape auto trace of the image you provided produces the following. A better result could be obtained doing a manual trace. What drawing program do you know how to use? The result of the autotrace could be "tuned up" with some node editing to very closely match your original image. As it is now, you can see some flat spots and other defects in the trace result.
smilintodd
Hi Joe, ya you helped me before, but the guy wanted the same logo. Its a bit different, so I scanned the actual piece.
smilintodd
adbuch wrote: Tue Nov 05, 2024 9:43 pm An Inkscape auto trace of the image you provided produces the following. A better result could be obtained doing a manual trace. What drawing program do you know how to use? The result of the autotrace could be "tuned up" with some node editing to very closely match your original image. As it is now, you can see some flat spots and other defects in the trace result.
Your second one looks really good. I've played with inkscape a bit, but not very well versed. I usually don't do much with art stuff, usually just parts with either dimensioned drawings or napkin drawings with dimensions.
smilintodd wrote: Tue Nov 05, 2024 10:16 pm
You can use an online program to remove the background to make it easier to autotrace.
https://www.remove.bg/
Then import the result to Inkscape for auto trace and cleanup. You can follow along with the steps I show below and see what you can come up with. Please be sure to ask any questions if you get stuck or need additional help.
I have created a slide show on Google Drive as well. Here is the link.
https://photos.app.goo.gl/bYSZ1KK5zG3ggVoq6
smilintodd
awesome, thankyou so much
What is HenryJ?
smilintodd
I guess it was a model or car manufacturer. They only made them for a few years in the 50's or 60's. From what I'm told they are popular to build into drag racing setups.
plasmanewbie wrote: Wed Nov 06, 2024 11:07 am What is HenryJ?
