Desigh Edge offset and snap example
Fastyankee
Re: Desigh Edge offset and snap example
Post by Fastyankee »
adbuch wrote: Tue Oct 15, 2024 9:58 am22.jpg23.jpg
Dave
What I find when you import a DKF in to Inkscape it comes in as a px and I convert it to inches. I never had an issue exporting the file from a SVG to a DXF though and I checked the dimensions to make sure it was in Inch and the correct size. The reason I was thinking I had a setting not correct.
AJ
irondeuces@gmail.com
Pulmax
5x10 Star Lab plasma, scribe, pipe cutter
60 ton 53” press brake
JD2 tube bender
Hulk Tube bender
Slip roll 3/16th capacity
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Fastyankee
Here is the file I was working on.
Steam Punk counter top.pcm
(662.7 KiB) Downloaded 25 times
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Joe Jones
Post by Joe Jones »
For 3D routing, look at V-CARVE PRO.
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
Joe Jones
Post by Joe Jones »
[m] = keystroke
@##,## = Type the coordinates, which will appear in the lower left corner of the screen
[w](click anywhere) @20,10 [ENTER]
[y] [6] [ENTER] [2] [ENTER] (click to place hexagon anywhere on work area)
[m] [c] (click on hexagon) [n] (click on top left corner of rectangle)
[m] (click ANYWHERE) @ 8.5,-4.2 [ENTER]
Fastyankee wrote: Tue Oct 15, 2024 7:27 am I’m trying to decipher this.
Bring up DesignEdge and type in this order...
w @ 20,10 - [ENTER]
y 6 [ENTER] 2 [ENTER]
m c (click on hexagon) n (click on top left corner of rectangle)
m (click ANYWHERE) @ 8.5,-4.2 [ENTER]
We need to have a ZOOM session!
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Fastyankee
Joe Jones wrote: Tue Oct 15, 2024 12:29 pm For 3D routing, look at V-CARVE PRO.
I only work with Plasma and Tube bending.
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Fastyankee
Joe Jones wrote: Tue Oct 15, 2024 12:37 pm [m] = keystroke
w @ 20,10 - [ENTER]
Zoom call would be awesome Thanks
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Fastyankee wrote: Tue Oct 15, 2024 12:28 pm Here is the file I was working on.
Andrew - Robert made this video for me back when I was first getting started with Design Edge and had many questions. I think you will find it very helpful in answering many of your questions about editing and cleaning up problematic files.
https://www.facebook.com/learnplasmacam ... 0346275313
Joe Jones
Post by Joe Jones »
Did you purchase and activate the Advanced DesignEdge Upgrade? If not, the task of cleaning up problems is more labor intensive.
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Fastyankee
I made a simple switch panel today in Inkscape rather than Design edge because I just could not get the scaling done. I was pretty much chasing my tale in Design Edge. The biggest issue I have is the snapping tool when I use it for scaling and measuring it just doesn't seem to put me on the line I'm trying to scale or measure. I than imported it in to Design edge to use the trim tool because Design Edge has a very good trim tool.
I also tried to import a picture of the panel to see if I could just duplicate that and that was a nightmare. I only ned to make the switch panel a little bigger and I ended up having to recreate the whole panel.
Switch Panel.dxf
(64.79 KiB) Downloaded 23 times
Switch Panel.dxf
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Joe Jones
Post by Joe Jones »
Your switch panel.dxf file is not even close to the photograph you posted here.
I am not sure which direction to go! :roll:
Do I draw a file that matches the photo? Or do I use your switch panel.dxf file as the starting point?
Help me out. What is the actual X/Y dimension of the rectangular plate? What is the actual diameter of the large hole at the top left position on the plate you want to produce?
DesignEdge can easily draw this panel, but not without accurate dimensions as a guide.
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Fastyankee wrote: Sun Oct 20, 2024 5:24 pm I made a simple switch panel today in Inkscape rather than Design edge because I just could not get the scaling done. I was pretty much chasing my tale in Design Edge. The biggest issue I have is the snapping tool when I use it for scaling and measuring it just doesn't seem to put me on the line I'm trying to scale or measure. I than imported it in to Design edge to use the trim tool because Design Edge has a very good trim tool.
need dimensions.jpg (89.45 KiB) Viewed 5616 times
Joe Jones
Post by Joe Jones »
In order to draw this panel correctly, you need to provide dimensions 'a' through 'r'
I will assume this panel screws to another component, so the screw holes MUST match up on both the X and Y dimensions.
I will assume that the components that fit into the six rectangular holes must fit into the holes, and therefore the holes cannot be drawn to match the photo, but must be sized correctly to fit the existing components that will snap into those holes.
I will assume that holes for the components that fit into the one round hole, the two additional shapes with a radius on the top and bottom, and flat vertical sides, and the six round holes with flat tops and bottoms, and radius sides must all fit the existing components that will be inserted into them, as none of these components can be scaled to fit improperly drawn holes.
So all of the dimensions in the attached photo must be known, in order to draw this panel correctly.
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Joe Jones
Post by Joe Jones »
Fastyankee,
The rectangular holes you DREW in your .dxf file are disproportionate to the rectangles in the photograph. Are you going to use different switches in those holes, because the switches that fit into the holes in the photo will not fit into the holes in your .dxf drawing.
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Andrew - I think we are getting you squared away with your rectangles and snaps. I realize that the part you drew was not supposed to be exactly like the part you showed in the photo. That was just an example. Like we talked about on the phone, for the center snaps you mouse click just inside the outer perimeter of the circle, rectangle, etc. Or you can click directly on the line, as Robert mentioned. But once you have added those fillets to your rectangles - the center snap will no longer work. What I like to do is to draw a line from midpoint to midpoint of the rectangle, then use the midpoint snap when selecting the rectangle (this will be the center of the rectangle with filleted corners) and then place it to your destination using the appropriate snap.
Joe Jones
Post by Joe Jones »
A switch panel that is not symmetrical will forever poke you in the eye.
http://youtu.be/ego4Utdmf_M
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Andrew - I have also emailed you with more information. Let me know how you are making out.
Fastyankee
adbuch wrote: Mon Oct 21, 2024 4:40 am Andrew - I have also emailed you with more information. Let me know how you are making out.
Dave I appreciate the help. I had to make a bigger switch panel than the black switch panel in the pic. I was trying to draw the dimensions from the existing panel such as switch holes but the plate its self needed to be 5.5 high x 7.75 long to cover an existing hole in the dash.
I couldn't even get the basic shapes drawn in design edge which was very frustrating to the point like I said I ended up drawing it in Inkscape.
I did end up cutting the panel and it came out ok but not perfect. I do have to compare my cut dimensions against my drawn dimensions to see if I need to adjust kerf because the wholes were to small on everything.
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Fastyankee
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
