CNC Wood Machine
- CNC_rowdy
CNC Wood Machine
I know this is a plasma forum, but does anyone know of a program to run a wood carving machine? I was looking at a Genmitzu. Just a new toy in the garage to play with. Maybe someone has something like this.
Timbo
Timbo
Go Torch 2x2 Table
Advanced Design Edge, Machine Control, Height Control
Snap & Cut Torch Holder
Hypertherm XP 45 Plasma Cutter & Machine Torch
- jmersereau
Re: CNC Wood Machine
I use Vectric software and really like it on my wood cnc router. It is very good and they have a variety of programs to suit your different needs and budget. https://www.vectric.com/
PrimeWeld CUT60
Langmuir CrossFire Pro
There are many different software packages to CNC wood or other materials like plastics. There are 2 categories to look at, 2-D is basically cutting with no change in depth, X and Y only. And 3-D which is multi level cutting with all axis moving during the cutting action. Programs like Fusion 360, Carbide Creates, and others. I use my table for both, attached image of wood inlay and epoxy inlay of a rose. These are call "V" carved which are 2-D routing.
I use Vectric Aspire to create tool paths for my cnc routers.
I don't a router but I have used my buddies and he is using the Vetric Aspire software and I like it, works very well and simple to learn.
- CNC_rowdy
Thanks for all the replies everyone. I just plasma cut at the time. I was just looking to maybe get a low cost router set up to play around with.
Thanks again for directing me to somewhere to start for looking at.
Timbo
Timbo
Go Torch 2x2 Table
Tim - you should be able to mount a small router onto your go-torch table and do some basic routing/engraving. Very similar to what you are doing with your sharpie pen holder.CNC_rowdy wrote: Tue Jun 04, 2024 1:23 pm Thanks for all the replies everyone. I just plasma cut at the time. I was just looking to maybe get a low cost router set up to play around with.
Timbo
You have 2 paths to go with either a standard router or a spindle. Quick and easier one is a standard wood router, I have used a 120 VAC 2.25 HP Porta Cable on a few tables. You can get a 120 VAC (or 220 VAC) spindle but it requires a VFD and maybe water cooling. A spindle speed control can be done with the software and a router is with a dial on the router. I use a Solid state Relay to control the standard router along with the Vac system from the controller with a small switch. Add a router and increase the CNC fun time.
https://drive.google.com/file/d/1ZSYP_W ... sp=sharing
- CNC_rowdy
Thanks David on the router info. I have YouTube vidz on it. I will look into it. Just got the marker holder today, gonna try it out directly. Also acouryjester thanks for your input to. I am gonna look into it all.
Thanks again,
Timbo
Thanks again,
Timbo
Go Torch 2x2 Table
Tim - for your small 2x2 table, I would be inclined to purchase something like this one.
https://www.ebay.com/itm/326149395041?e ... BMsvm4y_xj
Then maybe come up with a simple mounting bracket - I expect it could be 3D printed.
- CNC_rowdy
Thanks all,
Tim
Tim
Go Torch 2x2 Table
