welding fixture table top
All topics related to mig welding, tig welding, spot welders, flame cutting, etc.
Re: welding fixture table top
There are slight changes between the base assemblies, like the pivot point and the angle fences for making angled cuts.
Here is a link for the Google drive with a folder with many images of the construction and a PDF file with some descriptions.
this used a Harbor Freight saw but I'm sure slight modifications to other brands would work too.
https://drive.google.com/drive/folders/ ... drive_link
https://drive.google.com/drive/folders/ ... sp=sharing
Thanks Tom!
Dirtmotor
Post by Dirtmotor »
Newest tool for shop , its a slip roller and works better than I expected !
Dirtmotor wrote: Wed Jun 26, 2024 9:03 pm Newest tool for shop , its a slip roller and works better than I expected !
Nice!! What brand is it?
Dirtmotor
Post by Dirtmotor »
Thanks David I built it from scrap laying around the shop . Watched a couple of videos of people building one , then adapted what I had . The rollers are 1 1/4 " heavy walled pipe . with 3/4 bolts acting as axles .
Dirtmotor wrote: Wed Jun 26, 2024 9:27 pm Thanks David I built it from scrap laying around the shop . Watched a couple of videos of people building one , then adapted what I had . The rollers are 1 1/4 " heavy walled pipe . with 3/4 bolts acting as axles .
Nice!! How thick is that piece you rolled with it?
Dirtmotor
Post by Dirtmotor »
That one is 14 gauge , I did some 11 gauge thats probably its limit .
I built a plate roller some time back, I used DOM tubes telescoping inside each other for the rollers. It was 13" wide, I could do 3/8" for some narrower plate, used it to make a large wheel for the plate roller. Had to move outside due to the length of the tube I rolled. I also rolled some smaller wheels for a rail road luggage type cart I built, Sold it to a guy making fire pits. :Like
That's pretty awesome Tom! Thanks for the pics of your machine, very clever design :Like
Dirtmotor
Post by Dirtmotor »
Tom thats a heavy duty one for sure ! I like the jack idea .
tinspark
Post by tinspark »
I bought a 36" Pexto slip roll 25+ years ago. Which is in perfect shape to this day.
But it will not budge the thicker stuff.
Those both look awesome!
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
elmendalerenda
Post by elmendalerenda »
Using the plasma table for the cut and sealing the edges with masons flex is a nice touch. How's the flap wheel finish holding up?
Dirtmotor
Post by Dirtmotor »
Looks good so far
Tom - that is a pretty impressive machine you built there! Heavy duty - to say the least. I bought a new Pexto slip roller back in 2000 for a project rolling some copper sheet for cooling jackets. The slip roller is only rated at 22 ga. full width, but it did handle the 0.060" thick copper fine. These were only about 12" wide or so. I have also used it for 0.060" aluminum for making fan shrouds. I do sometimes wish I had something more robust - like maybe the one dirtmotor built.
Dirtmotor wrote: Thu Jun 27, 2024 8:22 am That one is 14 gauge , I did some 11 gauge thats probably its limit .
One like yours that can roll 11 ga steel would be great to have. Perhaps I will need to take a closer look at your build and maybe come up with something similar. Do you have any links to the videos or articles you looked at when you built yours?
Dirtmotor
Post by Dirtmotor »
adbuch wrote: Sat Jun 29, 2024 8:55 pm
I cut two of these ends and 4 top plates also cut four more partial top plates to shim it out far enough so the 3/4 all thread adjustment bolts can pass through to bear down on bearings on center roller , I had some 2 foot pieces of 1 1/4 DOM with 3/4 center holes so I simply cut 3/4 bolts and inserted into dom and used roll pins to attach . I used a couple of motorcycle sprokets for chain drive , only used bearings on center roller and put a couple of small angles on out side of bearings to keep bearing centered . The bearings are just there so the all thread is not bearing on center roller axles directly .There are 4 3/8 grade 8 bolts holding the removable adjusters in place .I used 2x2 x1/4 angle iron for side support . Dont remember which videos I watched . Hope this helps .
Dirtmotor wrote: Sat Jun 29, 2024 9:22 pm Screenshot (46).pngScreenshot (45).png
Thanks! I will look this over and let you know if I have any questions.
Always great to see how other do their DIY projects, nice job Dirtmotor
Return to “Mig Welders, Tig Welders, Spot Welders”
